Old 09-17-2018, 07:30 PM   #11 (permalink)
teoman's Avatar
A3 - '12 Audi A3
I think that you should somehow find the specs for the battery pack.
Can you see the cells in the pack?
Old 09-18-2018, 12:43 AM   #12 (permalink)
SUVcruiser - '07 Ssangyong Kyron 2.0 XDI
90 day: 42.55 mpg (US)
SUVcruiser year 2017 - '07 Ssangyong Kyron 2.0XDI
Hybridcruiser 2023 - '13 Volvo V60 D6 AWD
90 day: 123.84 mpg (US)
The battery is closed.
Drive smart, save fuel, save money, spare the enviroment
But keep having fun!
I can drift
Previous car. SUV. From 2011+ 10l/100km to 2017 5,516l/100km.
2017 without holiday: 5,397l/100km
EPA Rated average: 8,1l/100km
Current ride: plug in 285hp hybrid
EPA Rated average: 2,8l/100km
Old 09-18-2018, 01:51 AM   #13 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Do you have any access to the High voltage terminals?
If you want to fiddle with high voltage that is.
Old 09-18-2018, 01:55 AM   #14 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Maybe something like this:
Look what I found on AliExpress
DC DC 8~32V to 45~390V Adjustable High Voltage Boost Converter ZVS Step up Booster Module Capacitor Charge Board New Arrival-in Integrated Circuits from Electronic Components & Supplies on Aliexpress.com | Alibaba Group
(This one is only 200mA output)
To directly feed the pack.
With a half full pack, you should not have any balancing issues. And you can assemble your cells to low voltage configurations.
Old 09-18-2018, 02:31 AM   #15 (permalink)
The orange wiring are the high voltage cables. The only problem is that there are way to many cables running from the battery to ... that i have no idea what the main voltage cables are... Thats something i want to know.
I can drift
Old 09-18-2018, 12:15 PM   #16 (permalink)
Just an assumption that you are questioning the Volvo hybrid in this thread ?
The voltage is 400. If you can locate the inverter that drives the motor, that will show the HV cables.
About the extra cells that you want to solder together, if this is what you mean, I would vote against soldering and get a resistance welder that spot welds nickle strips to the cells, quickly, without heating the cells, which will have very detrimental effects on the cells.
If you are not sure about the inverter location, respond here and I will do some research for that location. I will also try to find a printout of the cables exiting the battery for the Volvo hybrid ? Does this image help you ?
https://commons.wikimedia.org/wiki/F...nd_battery.jpg
Old 09-18-2018, 08:14 PM   #17 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
If you stop charging at 14.6v (~80%), your lithium batteries will last longer.
Second vote for NOT soldering batteries!
Old 09-19-2018, 12:40 PM   #18 (permalink)
teoman's Avatar
A3 - '12 Audi A3
http://youtu.be/o1NFbchHeM8
Diy spot welder.
Old 09-19-2018, 01:36 PM   #19 (permalink)
That spot welder looks super easy. In fact, i have all the stuf laying around to make one myself.
The only problem i see, what if one cell fails? It shorts all the parallel cels with it.
Ive opend a lot of electical bike batteries with shortet out cells because of a single failed cell. That is only 500Wh. But when i have 1200+ cells ... That is 11 000Wh
More then enough to start a big fire...
I can drift
Old 09-19-2018, 01:41 PM   #20 (permalink)
Ive had my trunk dismanteld to the level of the pics ive posted. So far i did not had enough evidence to point out the main leads. I have filmed it and hope to upload it tomorrow.
This here is pioneerwork. This is never been done before. So not an easy task.
Hope it will work out.
Going to contact Volvo to hopefully get some help.
I can drift
