Old 06-06-2010, 10:27 AM   #1 (permalink)
Air Condition vs Windows Down
Do you got more mpg with.....
a) Air condition on and windows up
b) Air condition off and windows up
or
c) Air condition off and windows down
I have seen a couple of articles that question that b or c is the better of the two. But I dont have an exact answer.
Old 06-06-2010, 10:39 AM   #2 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
B would be the best, but I'm wondering about the comparison between A and C, since I removed the air conditioning, and I'd like to know if rolling down the windows is worse than having the AC on.
In Reason we Trust
Old 06-06-2010, 10:39 AM   #3 (permalink)
Lex Luthor - '10 Lexus HS250h
90 day: 70.18 mpg (US)
I would think in all situations, b) would definitely be the best. Whether a) or c) is better has been an ongoing debate and depends an the circumstances, the primary one of which I believe is speed. This assumes your a/c is working properly.
Old 06-06-2010, 10:56 AM   #4 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
I've seen a lot of tests, and people always test with all windows down versus A/C
I usually run one window open (or just cracked even) and no A/C and feel this is the best way, up to at least 70 mph, which I never go that fast anyway.
Old 06-06-2010, 11:00 AM   #5 (permalink)
Factory aero design works best with windows UP. If you feel guilty about running the A/C slow down 5 mph and you'll get even better mileage.
Old 06-06-2010, 12:51 PM   #6 (permalink)
ChopsQube's Avatar
Nissan Cube - '10 Nissan Cube Base
90 day: 33.35 mpg (US)
The BRG - '91 Mazda Miata SE
90 day: 35.9 mpg (US)
It has been proven by several organizations, including MythBusters and myself that driving with the a/c on and windows up is better than driving with the a/c off and windows down. It's a simple comparison that you can easily conduct yourself. There's really no reason to see what others have to say.
Although, I don't think that "B" should even be an option as the answer is clear. No a/c means less drag on the engine, and all windows closed means less air drag which in turn means less drag on the engine.
However, running with the a/c off and the windows up in the summer time in the more tropic areas of the world when you have a car with a perfectly functioning a/c system, I'm willing to sacrifice a couple MPG to be comfortable. The a/c in my first vehicle died six months after I bought it and I couldn't afford to get it fixed. I never want to repeat that ever again.
Old 06-06-2010, 01:44 PM   #7 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
Using the a/c intermitently fetched me some decent mpg figures. But whenever it is feasible, I crack open a window (or the sunroof) and use the vents.
I'm with ChopsQube, a couple mpg loss is worth it to not sweat like a horse. But there is a lot to be said about finding a happy medium between windows down and ac cranked full blast. In my van I'll turn off the a/c as much as possible or turn the blower to the lowest setting; makes me wish for a thermostat inline with the a/c switch.
Be careful mentioning mythbusters around here; you'll be told how unscientific they tend to be.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 06-06-2010, 01:45 PM   #8 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
I think the answer depends on:
  • The make and model of the car,
  • How efficient its A/C is,
  • How many and how much the windows are opened.
Check out these two threads:
Windows down on VW Golf = 2.5% FE reduction
Tested: what's the resolution of coastdown testing? Can it register an open window?
The Following 2 Users Say Thank You to Piwoslaw For This Useful Post:
Cd (06-06-2010), NeilBlanchard (06-06-2010)
Old 06-06-2010, 01:54 PM   #9 (permalink)
thanks for everyones feedback. I was pretty sure b was the correct one, but wasn't sure on a and c.
BTW: Love the forum
Old 06-06-2010, 02:18 PM   #10 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Piwoslaw -
These are good points. For instance, if you have a V8, the A/C is a lower percentage of your engine load, so it's a more reasonable tradeoff. On my 1.9 liter 4-banger, it has a much bigger effect and I can really feel the HP drain when I try to accelerate. I can see A/C killing my MPG on the ScanGauge because the engine load is much greater.
And yes, b is best, but it can be a hard thing to do in August. I usually do what brucey does, window open or cracked. When I hit bad traffic and have to slow down, I lower all the windows a lot until things speed up again.
CarloSW2
American Solar Energy Society
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
start to play with IAT sensor on Mercedes E250D-Turbo 98' poisas EcoModding Central 6 10-07-2013 04:13 PM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
