Old 07-18-2010, 03:29 PM   #11 (permalink)
Hypermiling rookie
Laurentiu's Avatar
Opel Corsa B - '96 Opel Corsa 1.2 8V
90 day: 47.27 mpg (US)
VW Bora 1.6 16V - '02 Volkswagen Bora/Jetta
90 day: 35.84 mpg (US)
Originally Posted by JellyBeanDriver View Post
More like coatings to reflect infrared energy instead of letting it in to bake the interior.
well...both actually low conductivity and low emissivity (keep the cool air in when the AC is on and keep the heat out)
"It has been my observation that most people get ahead during the time that others waste" Henry Ford
Old 07-18-2010, 04:04 PM   #12 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
What is this ac of which you speak?
Nissan Versa Aeromods
Old 07-18-2010, 04:26 PM   #13 (permalink)
Hypermiling rookie
Laurentiu's Avatar
well...i know I'm talking nonsense because my car "don't have no AC" and even if it did I would probably keep it off
Old 07-18-2010, 04:29 PM   #14 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
95+ degrees...85%+ humidity.... no A/C I sweat all the time
Old 07-18-2010, 11:10 PM   #15 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Your IMA battery thanks you for AC though. I was just talking with the owner of hybridbatteryrepair.com this weekend and he says heat is the number one killer of packs.
Ron is correct that heat kills IMA batteries, and if your battery overheats, a blast of AC can bring its temperature down faster. Though AC use is from mandatory for the Insight. The battery fan comes on around 140F, and you can keep the cabin under 100F with a sun shade when parked, and lowering one window while driving. Add an assist/regen disable switch, and the battery will hardly ever heat up unless you're in hills too steep to EOC down. Add a MIMA or other custom fan controller and the fan will come on at a lower temperature.
Old 07-18-2010, 11:12 PM   #16 (permalink)
Left Lane Ecodriver
I really can't fathom that combination of heat and humidity. I was really suffering on a 90F, 60% RH day.
By the way, Daox, did you check out the window tint on Ron's Insight? It's 30% VLT, IIRC, and he says it keeps things much cooler inside.
Old 07-19-2010, 03:13 AM   #17 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by Laurentiu View Post
L.E. it is appalling to think that the few cubic feet of cabin space in a passenger car which are 10's of times less than the size of 1 room require such vast amounts of Watts to keep it cool..
If that room was a greenhouse...
Old 07-19-2010, 04:11 AM   #18 (permalink)
Hypermiling rookie
Laurentiu's Avatar
yes, i agree it's a greenhouse, but is it absolutely necessary to be like that ?
Old 07-19-2010, 06:46 AM   #19 (permalink)
In Parris Island at basic training my brother saw a midnight temp and humidity of 99 each.
Best time for max AC is DFCO since its basically free. With 46 lights in 40 miles, it's inevitable that you will catch a couple of them. The VX's 5th gear is so tall you can get 10-30 seconds of DFCO-AC operation before engine speed drops down to low to maintain DFCO.
Just use the AC compressor, max fan, and recirculate, min temp and downshift as you slow to maintain DFCO RPM which in the VX is about 1200 RPM.
The threshold for me now is in the lower 90s temp wise and humidity here is rarely below 75%.
regards
Mech
Old 07-19-2010, 10:26 AM   #20 (permalink)
mrk
Yaris 1.0 Liftback - '09 Toyota Yaris
90 day: 50.85 mpg (US)
I sometimes think about using evaporative cooling in a a car, if humidity is low it can be a good alternative, where I live it's only about 20%...
Has anybody tried to use a "swamp filter" somewhere in the ventilation system?
For short distances it might not be necesary to keep that filter swamp, just wet it at the start. The easiest I thougt is like a "straw filter" between two wire mesh to keep everything in place. Just place it in the intake of the ventilation, pour a bottle of water on, and let's go. For a longer effect you need to keep it humid, of course... not difficult though.
I also have seen this
Product Profile
but something like this will hurt aero too much...
Of course this is not valid for folks enjoying +75%
M
MrK
Ram Air vs. HAI vs. Warm Ram Air. Tygen1 EcoModding Central 34 08-10-2014 04:28 AM
My New 4cyl Compact Doesn't Get Good Mileage Stone Axe Introductions 13 02-08-2013 12:06 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Increase FE with warm air intake silverhawk_184 EcoModding Central 6 12-03-2009 11:45 PM
OEM Air Injection, Yay or nay? Dane-ger EcoModding Central 11 01-14-2008 10:05 AM
