Old 02-16-2013, 05:49 AM   #1 (permalink)
Almera 2.2 sport+ (2000) wont start..please help!
Hello, I have a Nissan almera 2.2 sport+ (2000), I started to have problems with starting the car first time until eventually it wouldnt start at all, I was told it was the starter motor so I purchesed another, I have fitted the new starter motor and it still wont start, all I get when I turn the ignition on is a clicking noise, Just to make sure there wasnt a fault with this starter motor I had it bench tested and it fires the cog out no problem but as soon as it is fitted back onto the car and ignision is turned all you hear is a sound like an electric motor turning coming form the starter motor but its not fireing out to engage with the engine.
Old 02-16-2013, 06:55 AM   #2 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
Will it start if jumped? It sounds to me like a weak battery if you already replaced the starter. which means it could also be the alternator not charging the system back up
"The only real mistake is the one from which we learn nothing."
- Henry Ford
Old 02-16-2013, 07:01 AM   #3 (permalink)
Thanks for your reply....It wont start form jump leads from another battery and ive just tried my neightbours battery in my car and that wont work either..its got my head banging ha.
Old 02-16-2013, 07:29 AM   #4 (permalink)
The Dirty330 Modder
Gealii's Avatar
well all i can think of is checking the hot and ground wires to the starter. If the problem got progressively worse and then u replaced the starter. then i could see either a bad connection or a locking motor
- Henry Ford
Old 02-16-2013, 07:32 AM   #5 (permalink)
Thanks again for your reply....what do you mean by a locking motor?
Old 02-16-2013, 08:21 AM   #6 (permalink)
The Dirty330 Modder
Gealii's Avatar
like if you find a car from the 70s that hasnt been started since then the motor has seized together unable to move. i highly doubt it but u never no anymore. just like the motor tried to destroy itself and why it was getting worse
- Henry Ford
Old 02-16-2013, 08:51 AM   #7 (permalink)
some one has just told me that it could be the cam/crank sensor..could they be right??...if so where is the cam/crank sensor located??..again thank you.
Old 02-16-2013, 09:15 AM   #8 (permalink)
The Dirty330 Modder
Gealii's Avatar
Both could definitly do it and if there starting to fail would not throw codes until its completely bad.( How'd i forget those i had replaced both on a car, i guess it was because it didnt fix my issue, but my ecu was dieing come to find out). the crank sensor is by the starter, and i couldnt find the 2.2 cam sensor but depending how close the 2.5 is in comparison...
- Henry Ford
The Following User Says Thank You to Gealii For This Useful Post:
derrick1551 (02-16-2013)
Old 02-16-2013, 10:37 AM   #9 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
The sensors will keep it from starting, but it wont affect the starter motor in any way.
Old 02-16-2013, 10:59 AM   #10 (permalink)
Jyden's Avatar
Enduro E-bike - '11 PowerPedals Enduro
90 day: 2236 mpg (US)
Jota - '14 Toyota Yaris Hybrid H1
90 day: 53.11 mpg (US)
Is it by any chance stuck in a gear? Is it possible to push the car? If not it' stuck in a gear. Some time this can happen with an old worn gearbox. Try to push or tow car and get i aout of the stuck gear?
My Yaris Hybrid thread:
http://ecomodder.com/forum/showthrea...s-c-27995.html
