12-15-2018, 10:18 PM
#11 (permalink)
I have an L not an S series however I have noticed when coasting out of gear my idle stays high based on vehicle speed. It stays at 1500 or so above 30 mph. As I coast down to stopped the idle returns to normal. I have also found if I kill it and restart it while rolling everything comes back except the cruise control. I do alot of fuel cutoff decel but very little engine off coasting due to loosing the power steering in this big heavy car. When I drove a Metro the engine was off quite a bit on my commute.
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
12-16-2018, 01:53 PM
#12 (permalink)
Originally Posted by Ecky
I'm wondering if there's a push-button way to simulate momentarily moving the key to a lower position that will kill the engine.
Should be able to cut the power/ON wire going to the ECU...it won't think that the engine stalled this way, and should keep normal idle after restarting.
Don't know what drawbacks there might be from doing this.
12-17-2018, 09:49 AM
#13 (permalink)
Thanks all, for the replies above.
I'm pretty sure the IAC isn't the problem, since the high idle even happens during later gear changes, not just immediately after a kill-and-restart. The ECU would have reset it to where it wants it long before that.
I don't think the ECU controls the lights, but the same switch position that shuts off the ECU shuts off the (daytime) lights.
The kill switch is wired to a normally-closed relay, whose contacts are in series with the +12V feed to the fuel injectors (very easy to wire in, as my circuit just plugs into the dedicated fuel injector fuse's slot). The ECU isn't "aware" of this mod at all. As far as it's concerned, the engine just stalled for no apparent reason.
I guess I could kill the power to the ECU instead, but as you've mentioned, that doesn't solve the airbag problem. It also means that Torque will disconnect from the OBDII port, since the ECU will have vanished. I also wonder how the ECU would respond to waking up in a car that is already in motion.
One other data point. When the car is in this high idle state, if I stop at a light and don't turn the engine off, the idle eventually settles down, dropping to about 1000rpm (which is still a bit fast) after about 30 seconds of high revs (which feels like forever, and burns a lot of gas).
Stefan Vorkoetter: Programmer, hobbyist, amateur watchmaker, pilot, and collector of fountain pens, slide rules, calculators, and watches.
12-17-2018, 05:35 PM
#14 (permalink)
I’m definitely going to watch this thread, for it stands to reason that if you’re getting a high idle with the kill switch in your S series, I could end up with the same unintended result in my ION...
My current Ecotec project...
My last Ecotec project...
12-19-2018, 11:54 AM
#15 (permalink)
thought about this for a while: I think the problem is that the CPU is looking for a tach signal which it won't get with the engine dead and not spinning. Obviously, empty cylinders/ engine compression during coast will act as a coast retard. So: your kill relay will need to add some sort of PWM signal to the ECU tach input that looks like the engine is running at some RPM at or above idle. the ECU should tolerate some stumble or momentary lack of signal, and with throttle off during the kill process just think it is coasting. I know the process in my F250 is: ecm doesnt care what rpm the engine is at during coast, it doesn't add fuel until idle drops to about 1000 rpm (because it "Romps"), taken from the TDC cam sensor. perhaps a 555 timer circuit running as an oscillator?
12-20-2018, 10:04 PM
#16 (permalink)
Master Ecomadman
Yes, put a piece of vacuum tubing and a drywall screw to expand it in the idle valve intake port, its the small hole (5/16 dia) on the bottom of the throttle body bore. This will lower the idle. You might get an error code, I just ignore it. May need to give it some throttle after cold start till it warms up a little.
- Tony
12-28-2018, 03:17 PM
#17 (permalink)
I guess what I really need is something whose speed is triggered by the fuel injector pulses as soon as I turn off the power to the fuel injectors. Something that pretends to be an engine based on the fuel the computer thinks it's feeding the engine. I'll need to do some diagnostics to determine the relative timing between the FI pulses and the tach signal, and then whip something up to fake this out.
12-30-2018, 11:42 AM
#18 (permalink)
Master procastinator
How much you actually save fuel using a kill switch?
Is it really worth the hassle?
12-30-2018, 03:40 PM
#19 (permalink)
Rat Racer
I'd rather all Saturns came with DRL kills.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
12-31-2018, 12:08 PM
#20 (permalink)
In city driving, probably a lot. It's less clear cut for my commute, but there are about 3km (out of 45) during my commute where I don't need the engine. With the engine idling, I burn about 2.5L/100km on those parts. With engine off, 0. Averaged over the whole trip, that's about a 0.17L/100km saving. Averaged over a year of driving, around 18L of gas saved.
EDIT: That 18L/year is assuming I only do my commute (rural highways). Once I throw in the city driving, the savings become much more.
The Following User Says Thank You to stefanv For This Useful Post:
