Old 10-05-2012, 07:22 PM   #11 (permalink)
christofoo's Avatar
00C - '00 Toyota Corolla
90 day: 43.54 mpg (US)
I have a trunk mounted bike rack - pretty similar form factor to the hitch mount, just different attachment method to the car.
You definitely will get considerably better mileage with the bike on the tail than with the bike on top, even if you don't do a Kammback.
Are you sure you want the Kammback mounted on the rack? I think either car could have a Kammback mounted to the car as a separate item. For the hatchback, the bike probably won't even affect drag, and on the sedan it's probably a pretty small contribution, since it does stick out of the wake a little, but really not very much (the wake on sedans, excluding about the last 5 years of production, is a few inches above the trunk lid, I think). Of course the Kammback provides its own benefit in either case.
If you want it all on the rack you'd have to design it (with plenty of folks here ready to look at your ideas and give you pointers).
Old 04-07-2024, 03:53 PM   #12 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
I'll just brutally resurrect this long-necroed thread.
When our 3 person family travels, we fit the bikes inside the car to minimize aero drag:
But this configuration is quite demanding on time/ease of packing and unpacking, and while travelling we would like to sometimes quickly have access to the bikes for a short ride, but resign from this due to the hassle.
We do not want the fuel penalty of a roof rack, so most likely I will invest in a hitch and then a hitch-mounted bike rack. But I am afraid that even then the parts of the bike sticking out the sides (and possibly the top) will mess up the aero
This pic that freebeard posted:
and this random pic:
only confirm my doubts
So back to the original question: Can the bikes be made to fit:
  1. inside of the wake of the rear of our stationwagon?
  2. inside of the reduced wake of a Kammback?
Or is hiding the frame in the wake, but still getting the penalty of the wheels sticking out on the sides, the best compromise I can expect?
Two thoughts I had were:
  1. a rack where the bikes are oriented in forward direction. This would be very long, and hitch-mounted racks cannot extend more than 1 meter, iirc, so out of the question.
  2. taking off the wheels (maybe only front wheels) to make the bikes shorter and lower.
Any ideas, comments?
Or maybe in the years since this was originally posted someone has some practical experience?
The Following 2 Users Say Thank You to Piwoslaw For This Useful Post:
aerohead (04-13-2024), freebeard (04-07-2024)
Old 04-07-2024, 06:41 PM   #13 (permalink)
Thanks for the repost. That's the World's shortest stop sign. The car needs work and the bike is in pieces. Here's the earlier combo, with a roof rack:
And the Bug Bearer rack before I made custom bumper mounting brackets.
A folding bike hung wheels down on the rack would fit inside a Kammback.
It depends on the car, and depends on the bike. I cherry-picked an example article: flatbike.com/how-to-haul-bikes-with-a-car/
Number four:
4. The bike-friendly car.
Generally, we don’t buy an entire car just to carry a bike. Not explicitly, anyway. We buy a car that matches our lifestyle that includes biking, doing lots of fun outdoor stuff, and hauling all those things related to biking, after researching and verifying that our bikes fit.
So yeah, we’re really doing this–buying a $30K car as an accessory for a $2K bike.
Then they go on to making the bike fit the car.
Piwoslaw (04-08-2024)
Old 04-08-2024, 12:38 PM   #14 (permalink)
Expect that modern times have produced exceptions, I used a folding bike that was hand carry-able AKA: steyer puch "cobra" that was suitcase size folded. Have seen electric assist cargo bikes capable today that collapse to that size and it wouldn't take much to fair it into the turbulent area.
Old 02-17-2025, 06:50 AM   #15 (permalink)
I had a 50cc motorbike in my youth that needed to get to University and back, about 1000km away.
Off came the front wheel and then the bike was bolted to a fabricated hitch that bolted to the car's tow hitch where the ball normally went, using the original wheel bolt.
Yes the bit of hitch the bolt went through could rotate.
The chain was also removed just in-case the bike slipped into gear.
The rear tire was deflated a little to make it less 'bouncy' without the rider's weight on the bike.
Kinda like this, but with the front wheel removed and the wheel bolt, bolting the bike to the tow hitch.
That kept the nose down behind the car's trunk, out of the airstream.
And yes; how fast the bike could push the car was also 'tested'
(How 'The Vast Majority' can conclude that all that nose way up in the air and all that strapping down and worrying is better or faster than simply removing/replacing the front wheel is one of 'Life's little mysteries' to me!?
Then again, there are ...er... people who can't reverse trailers and sit waiting for someone for hours and great expense when they have a flat!??)
If you want aero; the same might be done with bicycles but removing the chain is unnecessary thx to the freewheel hub.
I'd definitely deflate the rear tire some to compensate for the fact that the rider's weight isn't on the bike, else it'll be VERY 'bouncy'!
If the bike has a rear suspension it's less likely to be airborne as often, but airborne cuts rolling resistance!
aerohead (02-17-2025)
Old 02-17-2025, 02:30 PM   #16 (permalink)
' off came the front wheel '
https://ecomodder.com/forum/member-a...est-foiled.jpgBurt Munro hauled his Indian Scout to the coast and back from his Invercargill, New Zealand 'shed' in this fashion.
It inspired my one-wheel trailer.
