Old 11-19-2016, 08:44 AM   #31 (permalink)
Delta Flyer - '94 Honda Accord
90 day: 31.31 mpg (US)
I love it when a plan comes together... That looks great!
Old 11-19-2016, 11:34 AM   #32 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
You will have to program the idle time off (no power) . The servo uses power to hold position.
--- for shutdown
Add a capacitor the power the unit after shutdown. program when the unit sees the engine shutdown to close the flap
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following 2 Users Say Thank You to gumby79 For This Useful Post:
Daox (11-19-2016), Isoldmysaturn:( (05-16-2017)
Old 11-19-2016, 11:44 AM   #33 (permalink)
Thanks RoadCyclist.
I got the rest of the bits all printed up last night. They all go together pretty well. The blade doesn't fit up perfectly. I'll get that sorted out though.
Next up I'll get the servo hooked up.
The Following User Says Thank You to Daox For This Useful Post:
aerohead (11-19-2016)
Old 11-19-2016, 11:58 AM   #34 (permalink)
--- for shutdown
Does the servo use power to hold position, or only when it gets pushed out of position? I'll have to hook up an ammeter and see how its been programmed.
Old 11-19-2016, 03:33 PM   #35 (permalink)
LittleBlackDuck's Avatar
CT - '11 Lexus CT200h Luxury
Most servos have plain spur gears but the ratio is quite high, resulting in a significant torque required to move them without power. There is no power used by the servo motor when in position, but the electronics uses a small amount. The pulse position tells the servo the desired position, which is compared to the internal position and the potor actuated till they match. If it is moved out of position it will resist and try to move back.
For closing after ignition off you will need a really big capacitor to provide enough power to close the grille, probably in excess of 100,000uF. You can use a resistive divider and an analog input to monitor the input voltage before the regulator to detect power off.
Simon
The Following User Says Thank You to LittleBlackDuck For This Useful Post:
Daox (11-19-2016)
Old 11-19-2016, 05:51 PM   #36 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
The load will be speed based bell curve accentuated by the off center pen .
Anxious to see the results of your testing. It will answer some of the questions I've had in my idea .http://ecomodder.com/forum/showthrea...all-33611.html
Former
87' Hyundai Excel
Old 11-20-2016, 09:44 AM   #37 (permalink)
I got it fully assembled and tested out, and shot a quick video. Its running a slightly modified version of the 'sweep' program that is an example of how to use the servo library. Obviously, this program just sweeps the servo back and forth.
I did hook an ammeter up to the servo while it was in use. Sitting idle it used 10mA. While it was moving it used 60-70mA. However, the program it was running does not actuate the servo at full speed (which would be fine for this application). I imagine full speed would draw a lot more power.
MetroMPG (11-22-2016)
Old 11-20-2016, 03:46 PM   #38 (permalink)
...beats walking...
Have you tried "cycling" it under a wind load, such as a hair-drier or desk fan?
Old 11-21-2016, 08:36 AM   #39 (permalink)
Nope, I have not tried that. I'll fire it back up today and see what I can do. I don't think I have a blow drier though... I know I have a fan but that is going to be a fairly low wind speed. Good idea though. Perhaps I'll just try to hold it with my hand and see how much oomph it has. I'm pretty confident that it'll be okay. There is a bit of travel that I didn't use in the servo. It has 180 degrees of rotation and I think I'm using about 110 degrees of that. If worst comes to worst, I can use more of that throw that for a bit more mechanical advantage. Also, as you can see in the video, I stop the servo actuator arm parallel to the push rod. This gives me tons of mechanical advantage since the push rod is pushing straight into the servo pivot point vs trying to rotate the arm.
Old 11-21-2016, 09:01 AM   #40 (permalink)
It doesn't look from the video like it is closing all the way. If true, you could lengthen the wire arm some.
Speaking of the wire arm, I'm not sure it would stay straight trying to hold a flap closed in high speed conditions.
(My 2 cents)
