Old 06-16-2008, 08:27 PM   #11 (permalink)
Red
Red's Avatar
Sounds like all it does is plug up your exhaust. Once plugged your cat heats up faster which is where you probably see any FE gains.
Old 06-16-2008, 11:16 PM   #12 (permalink)
Impatient Driver
chrislk1986's Avatar
98CivicHX - '98 Honda Civic HX
90 day: 40.02 mpg (US)
why not just insulate your exhaust with some of that pink stuff for 20 bucks? I'm sure that would be just as effective, and you could make your underbelly a little smoother while your at it.
I'm sure the blade is somewhat expensive, since people will buy it at any cost to save a buck.
Old 06-17-2008, 12:16 AM   #13 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
CorollaMaster,
this is BS, please, if it sounds to good to be true, it is to good to be true.
Your are very correct in questioning this type of nonsense. diesel
Old 06-17-2008, 12:35 AM   #14 (permalink)
sickpuppy318's Avatar
the mazda - '01 MAZDA Protege LX
90 day: 34.68 mpg (US)
"Conclusion: Although the Blade provides immediate benefit to the car’s emissions and gas mileage, the benefit increases significantly after driving the car a minimum of 50 miles with the device attached."
In other words, don't worry if you don't notice anything, that's what's supposed to happen.
Call channel five, get them broads over here, tell them of the tragedy of my trappedness.
Old 06-17-2008, 12:42 AM   #15 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
CorollaMaster -
I have read discussions on this gizmo before. The consensus was that it was bogus for MPG (it promised too much).
It definitely looks nice and blingy. From an emissions POV, it seems to do *something* :
http://www.bladeyourride.com/whatitdoes.html
Question: In the above it shows a picture of "28.7 grams of captured PM (Particulate Matter) after 8,500 miles". 28.7 grams doesn't sound much to me. What do you think? How much PM comes out of a normal car over X miles?
CarloSW2
American Solar Energy Society
Old 06-17-2008, 01:37 AM   #16 (permalink)
Red
Red's Avatar
Go with the old rule, 1 gram = 1 paper clip, so after 8k that car as spat out ~29 paper clips worth of soot. Its possible
Old 06-17-2008, 01:48 AM   #17 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
reformed -
Originally Posted by reformed View Post
Thanks for the link. That was the conversation I remember.
CarloSW2
Old 06-17-2008, 06:05 PM   #18 (permalink)
ecoRolla
CorollaMaster's Avatar
Sippin' Subie - '09 Subaru Impreza 2.5i Hatchback
90 day: 26.3 mpg (US)
Send a message via AIM to CorollaMaster
Awesome. Thanks for the link guys. That other thread was pretty informative. I think if I do anything like this, I'll buy their filter and make my own tailpipe addon. IF I do, I'll post the results!
-ecoRolla
2008 Corolla S - 11,000miles
Pre-Hypermiling Tank Average ~34mpg
First Hypermiling experiment w/o ScanGuage 43.4mpg
Hypermiling with ScanGuage around 51mpg!
Old 06-17-2008, 07:04 PM   #19 (permalink)
British Ecomod Hypermiler
AXMonster's Avatar
The AXe - SOLD - '97 Citroen Citroen AX 1.1i 5 Door
90 day: 46.78 mpg (US)
Foci - '03 Ford Ford Focus Tdci Ghia Estate
90 day: 64.37 mpg (US)
Here's my interpretation on 'The Blade'
Its a thick fabric that the exhaust gas passes through.
It causes increased backpressure.
The increased backpressure causes more exhaust reversion during overlap and therefore more 'natural EGR' for want of a better phrase.
The increased 'natural EGR' increases cylinder temperatures and therefore decreases catalyst lightoff time.
The increased 'natural EGR' means that for the same power outputs, the throttle position has to be greater to achieve the same intake airflow (i,e, to get the same amount of air & fuel in there).
You can get the same effect by fitting a couple of socks over your tailpipe or squashing the end down a bit!
Oh, and it collects carbon out of the exhaust that would normally justg drop out of the tailpipe in chunks Wow, big deal..... hardly saving the earth.
I'm calling snake oil LOL
1997 Citroen AX 1.1i SPI
2003 Ford Focus 1.8 Tdci estate
Ecomods: See my garage
Old 06-17-2008, 09:36 PM   #20 (permalink)
Impatient Driver
I just plain took my muffler off and all the soot collects where the muffler was. I've got a 2ft piece of exhaust with the mounting part. I drilled holes in the end and stuffed some steel wool in there and made it so the steel wool did not shoot out the back.
The results from that (which definitely had more backpressure than the stock muffler) were less than noticeable. In fact, i actually got my worst mpg.
With the muffler off I am getting the best mileage in my history of driving. Possibly due to the 30-35 lbs of weight dropped, but also I can fine tune the throttle while driving much better.
blade, fuel economy, gas, mod, save
Fuel Economy related papers tasdrouille General Efficiency Discussion 41 03-19-2021 06:31 PM
Video: Can Skinnier Tires Increase Fuel Economy? Peakster EcoModding Central 67 06-06-2019 12:27 AM
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 29 09-06-2018 03:09 PM
Why SUV fuel economy is so much more important than small car fuel economy... SVOboy General Efficiency Discussion 30 02-23-2009 06:26 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
