Old 07-09-2015, 04:22 PM   #21 (permalink)
I'd imagine they'd have a 'low water' light. If you run out of water, they'd really have to retard timing I would think to avoid knock.
Maybe just drop the boost pressure?
I honestly can't see the A/C system providing that much water, but I could be wrong. Also, that fuel efficiency increase is really going to take a hard hit if you have to use the A/C to refill the water supply.
From a psych chart, here:
https://lehighcheme.wordpress.com/20...etric-chart-2/
If the ambient air is at 25C and 60% RH and cooled to 5C there is ~12g - ~6g of water available per kg of air.
The heat energy that the A/C has to extract is ~56 - ~18kJ/kg. The power required is that figure divided by the A/C's COP and multiplied by the (in)efficiencies.
At 1.225kg/m^3.
How much water is needed?
The Following User Says Thank You to Occasionally6 For This Useful Post:
Xist (07-10-2015)
