Old 03-21-2016, 10:23 AM   #31 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
it's only 2 sets. pm address and will get it to ya.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
Old 03-28-2016, 09:26 AM   #32 (permalink)
Re energy absorption you might want to look at inverting tube energy absorber. They work very well and have a "square" force vs displacement curve so you can design to the g load you want to sustain. They are "one shot" devices and have to be replaced if used. Nice device because they are rigid before and after deployment.
Old 03-30-2016, 01:01 AM   #33 (permalink)
The finish is going to be done by blasting with medium glass beads.
Medium glass bead blasting appears to be what the diamond tread was finished with from the factory.
This is most of the way done now.
Next will be the rear bumper build, here:
http://ecomodder.com/forum/showthrea...ild-33628.html
aerohead (04-02-2016)
Old 03-30-2016, 12:34 PM   #34 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Some tuft testing on the corners will tell the direction and thickness ov the boundary lair. The research Ive run across you want the VG ( Vortex generator) to be @15° off of the direction of flo. Nice buld.
Gumby stay flexible.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 03-30-2016, 12:36 PM   #35 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
And 1/3 of the cord forward of the point of separation
Old 05-17-2016, 06:28 AM   #36 (permalink)
I have not updated this in a while.
Before I left I pulled some all nighters and a few good 28 hour days couldn't pull together, building my spot welder, spot welding that 13 gauge expanded stainless to the inside of the bumper, fully welding all around everything and bead blasted it with glass beads.
The supporting frame is structurally complete, just needs finishing, crushed iron slag blast, primer, paint, asphalt coating and such and build all the stuff that's going inside and behind the bumper.
Now that I finished the hard part I can work on the really hard part.
Here are some pictures before things got time crunched.
I think I took some finished pictures but then I think I stuck the memory card in my game camera. I may have brought it with me, just need to dig through my bags.
ID:	20086   Click image for larger version
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
aerohead (05-18-2016), deejaaa (05-17-2016)
