Old 05-19-2022, 06:13 PM   #21 (permalink)
EcoModding DIY aer.or
I couldn't find my Yokohama tires listed in the Michelin site.
Thank you... I've bookmarked the website for the future.
Old 05-19-2022, 07:09 PM   #22 (permalink)
I mentioned the Rocketail... I think earlier... which seems to have lost much of its support from retail.
I think is pretty compact, and has interesting flow data.
Mercedes IAA concept:
theodoretziegler.wordpress.com/2015/09/15/heres-mercedes-transforming-afterburner-tail-in-action/
It's hard to see from this angle, but the extension panels are fairly straight so the extrude from a body that tapers back to the separation edge.
aerohead (05-23-2022), Bigrigdave (04-23-2023)
Old 05-19-2022, 07:39 PM   #23 (permalink)
...and the way the wheel covers change shape is cool too.
Old 05-20-2022, 12:56 AM   #24 (permalink)
Cx9 - '18 Mazda CX9 Grand Touring
90 day: 31.41 mpg (US)
Prius - '10 Toyota Prius III
90 day: 57.8 mpg (US)
Tundra - '00 Tundra V6 long bed base work truck
90 day: 19.4 mpg (US)
Yokohama has a calculator of their own: https://www.yokohamatruck.com/tire-t...ngs-calculator
Looks like they list their 023, 101, 108, 109, 114, 517, 617, 703, 709, 712, and 715 tires on it...
The Following 2 Users Say Thank You to Drifter For This Useful Post:
Old 05-20-2022, 01:40 AM   #25 (permalink)
Thank you for the Yokohama site.
Old 05-20-2022, 01:44 AM   #26 (permalink)
90 day: 29.78 mpg (US)
I've thought an inflatable aero treatment made the most sense.
Make it so it's foolproof and easy, that lazy slobs will still be compliant.
Make it with relief valves so lazy forgetful slobs don't break things when they back into a loading bay without deactivating the system.
Maybe make it out of the type of rubber used in high end rafts (PVC?). Tolerates higher pressure and abrasion resistant.
Perhaps it could be made so that when the pump is reversed, the thing sucks back into a minimal storage compartment out of the way.
*Not implying all or even most truckers are lazy slobs
The Following 2 Users Say Thank You to redpoint5 For This Useful Post:
Old 05-22-2022, 01:49 AM   #27 (permalink)
it definitely has possibilities. And a way to get it to "deflate it" would be important, even for a RV.
Here's another one...neither really address this
The Following User Says Thank You to sregord For This Useful Post:
Old 05-23-2022, 10:37 AM   #28 (permalink)
inflatable
I can testify that even 'mediocre' inflatable tails will show at the gas pump or charging station.
I'd link a photo, but the 'manage attachments' no longer exists.
Old 05-23-2022, 12:20 PM   #29 (permalink)
I've never understood the attraction of attachments. I raided your albums:
ecomodder.com/forum/member-aerohead-albums-pickup+images
aerohead (05-23-2022), Bigrigdave (04-23-2023), redpoint5 (05-23-2022)
Old 05-23-2022, 12:25 PM   #30 (permalink)
raided
Last two times I attempted to share images, there was no longer the 'MANAGE ATTACHMENTS' button to use.
Not sure what's happened.
Aerodynamics Seminar #1 - by Phil Knox MetroMPG Aerodynamics 7 08-08-2012 06:00 PM
Hub cap drag versus weight and heat bryan11 Aerodynamics 7 01-13-2010 02:37 AM
Hexagonal Dimples as a way to improve aerodynamics Palionu Aerodynamics 29 10-27-2009 12:39 AM
Aerodynamics Seminar # 5 - by Phil Knox MetroMPG Aerodynamics 4 01-29-2008 01:41 PM
Aerodynamics Seminar # 4 - by Phil Knox MetroMPG Aerodynamics 0 01-28-2008 08:36 PM
