Old 08-12-2014, 06:17 PM   #11 (permalink)
I guess much more than 10%. My Scangauge returned great results after each ECU reset. I might also install a switch inside to physically power the ECU off and let her start everytime from scratch...
Old 04-27-2017, 10:30 AM   #12 (permalink)
topcat's Avatar
Celica VVTI - '05 Toyota Celica GT VVTI
90 day: 41.89 mpg (US)
Hang on there. Negative LTFT means that the ECU is adding less fuel than its base map would expect. Surely that's a good thing... right?
In a car which has learnt a negative LTFT, resetting the ECU (back to its base map) is going to mean too much fuel gets added in until the ECU re-learns.
I guess it depends whether the error is in the final O2 meter or some place before that. Frames of reference and all that.
