12-25-2016, 08:34 AM
Conveyor belt material for air dams, etc
I have a lead on some Conveyor belting. Post in here if you have some interest and I will get a price.
It will be in 4' widths most likely, but I can cut it down if needed.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following 4 Users Say Thank You to skyking For This Useful Post:
12-28-2016, 01:23 AM
2 likes but not a single interest? That's just weird
I'll go with a dam down to about 9 inches above the ground on the truck. I plan on matching side skirts between front and rear wheels as well.
2003 TDI Beetle
2002 TDI Beetle
The Following 2 Users Say Thank You to skyking For This Useful Post:
12-29-2016, 12:42 PM
interest
No good deed goes unpunished?
12-29-2016, 04:26 PM
I'm interested.
I have a trio of trucks that have torn off their factory air dams due to . . . stupidity. If the conveyor belt material is tough and economical enough, I can save myself from . . . myself.
12-29-2016, 06:11 PM
beastie - '89 toyota hilux dolphin motorhome Puggie - '98 Peugeot 406 Lx
Hi would be intrested but im in uk too far to put a deal together
12-29-2016, 06:35 PM
T-100 Road Warrior
I'm curious on the thickness/plys of the belting. I would be looking at two 4'x4' pieces to replace my aging Coroplast rear skirts. If it ends up being too pricey including shipping, I'll probably look at going locally with aluminum diamond plate like I did fer my rear diffuser.
Dark Aero-The world's first aerodynamic single wheel boat tail!
12-29-2016, 07:17 PM
MPGuino Supporter
iNXS - '10 Opel Zafira 111 Anniversary Suzi - '02 Suzuki Swift GL
I might could be interested in enough material to equip my truck and my Durango with an air dam and possibly side skirts.
12-30-2016, 03:39 AM
I will check it out next week.
Here is the ad:
repurposed/ reclaimed/ scrap conveyor belting
It does weigh up quickly, so I will get about 9' for my truck job and weigh it.
It does not need packaging beyond being taped securely in a roll.
2003 TDI Beetle
2002 TDI Beetle
The Following User Says Thank You to skyking For This Useful Post:
12-30-2016, 06:50 AM
#9 (permalink)
I've often thought about some sort of material like that. If it is stiff enough I could run it to the road then not worry about dragging it through a parking lot.
I'm checking your link now.
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
12-30-2016, 10:31 AM
#10 (permalink)
I think if it is in a straight line it will bend back readily, after all it was designed to go around a relatively small roller. If you can make a slight arc with it, and support it halfway down with a backer rod of 1/4" steel it would behave nicely and still have that indestructible quality we desire. I'd just plan on any support being above the highest expected curb, so that is why I picked 9" for me. I want the whole thing above a typical curb, but if you put your backing support above the curb it should survive fine.
2003 TDI Beetle
2002 TDI Beetle
