02-09-2015, 06:21 PM
#11 (permalink)
look-alike
H.Schmude,GM Styling Staff,to Walter Korff,Lockheed Aircraft Corp.,at annual SAE Congress,1963,(paraphrasing)
"If cars were designed for low drag,would they not all look alike,and stylists have nothing to do?"
02-09-2015, 08:21 PM
#12 (permalink)
home of the odd vehicles
Originally Posted by ksa8907
Still waiting for someone to take the plunge and design an engine around e85.
A flexboost diesel could handle E85 today, just need a pair of common rails for every cylinder (oh wait that already happens on certain things)
02-10-2015, 08:30 AM
#13 (permalink)
Rat Racer
Here's the 2025 Suburban
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
02-10-2015, 08:58 AM
#14 (permalink)
Aerohead already pointed out the Insight, but look...
Here's the 2025? 1999 Insight
02-10-2015, 09:21 AM
#15 (permalink)
With 100 pounds of lithium batteries.
regards
mech
02-10-2015, 10:34 AM
#16 (permalink)
Ultimate Fail
I call bull on all cars having to look identical due to aerodynamics.
As an example, just look at the Gen 1 Insight and the Lexus LS430 - both have the exact same Cd.
There are plenty of areas for the stylist to do whatever they want.
The Following User Says Thank You to Cd For This Useful Post:
02-10-2015, 04:40 PM
#17 (permalink)
look/aerodynamics
In 1963,Walter Korff commented that stylists would have a great degree of latitude with cars down to Cd 0.20.
In 1969,R.G.S.White,at MIRA,commented that Cd 0.25 could be achieved with virtually all contemporary shapes.
A few years further on the head of Ferrari said the same thing.
In the mid-80s,Wolf Hucho also spoke of the creative license availed to stylists,when talking about vehicles with around Cd 0.25.
To venture into really low drag,either half-bodies or wing-type shapes would be required,as only these forms guarantee attached flow over the entire length of the vehicle.
Length becomes an issue,just as in the 1930s with Fachsenfeld's and Kamm's K-form car.
Here,Hucho suggested we revisit the 1930's 'extensible' tail,which would only be deployed on the highway.
02-10-2015, 05:36 PM
#18 (permalink)
...beats walking...
...and, that "extensible" tail could/would/should be labelled aerodynamic "rear-end collision" bag!
02-10-2015, 06:07 PM
#19 (permalink)
Arecb
That might put it in a favorable light with the NHTSA.
02-10-2015, 07:18 PM
#20 (permalink)
Ultimate Fail
" In 1969,R.G.S.White,at MIRA,commented that Cd 0.25 could be achieved with virtually all contemporary shapes. "
And here are the two cars I mentioned earlier - and both are at Cd 0.25 .
This is a good visual example of what you mentioned Phil.
I got to thinking about something related to these two cars. Toyota ( Lexus ) gives a quote of .25 for the Lexus LS 430 when it had the optional air suspension.
Honda gave a Cd of .25 for the Gen 1 Insight.
Recently, as we have seen, the Insight has been degraded to a .30 when tested in a different tunnel.
In this same tunnel, a Gen 3 Prius was tested at .26 - so only one count off of the factory figure.
If Toyota tested the Lexus LS 430 in the same tunnel as the Prius, then that would mean it has a Cd of .26 versus .30 for the Insight.
So the LS 430 could be four counts better than the Insight !
Thats a lot of freedom for designers between the two shapes.
