01-30-2010, 12:47 PM
Ultimate Fail
Cross wind drag and side skirts / 'tails
A few years ago, I added side skirts to my Civic.
I removed them since they add several feet of frontal area to the car when hit by a crosswind. *
What kind of FE hit does a car get from increased side frontal area ?
On a similar thought, what about boattails and the increase in frontal area that they produce ?
* Where I live ( the 'hill country' ) , there is a lot of wind that blows in from the sides of the car.
01-30-2010, 12:50 PM
Ultimate Fail
I wonder how crosswinds affect semis regarding FE.
I know that the semi becomes less stable, but is there also a big FE hit ?
01-30-2010, 02:35 PM
skirts/tails
Skirts should not project below the "bottom" of the vehicle and consequently should not aggravate it's side area.
I can't answer the question about drag vs increased side area.I've never seen anything published on it.There is a table published by EPA on wind/mpg effects.
One benefit of skirts in crosswind,is that they help cancel roll moments above the C.G.,actually increasing stability and safety to an 18-wheeler.
I've only run "short" tails,so I can only address those,and my experience so far is that they offer no degradation of stability,thanks to Professor Morelli's work at Pininfarina.
01-30-2010, 02:42 PM
I can only imagine underside airflow at a yaw angle is extremely complex. I don't think side skirts have a negative impact on drag even in crosswinds. Remember, the flow vector is very rarely gonna be perpendicular.
01-30-2010, 03:19 PM
T-100 Road Warrior
Got any piccies of yer vehicle with the side skirts on?
01-30-2010, 09:44 PM
Ultimate Fail
I knew that was coming ...............I'll have to find them.
( Not sure if I deleted them. )
EDIT : I found this picture, but it has some quick and sloppy Photoshop work . The skirts and wheel gap filler are real, but the diffuser thingee etc are Photoshop additions.
Phil : When you say that the skirts shouldn't project below the 'bottom' of your vehicle, what do you mean ? Do you mean the floorboard ??
( surely not )
Tas : Can you simplify what you said about 'flow vectors' going perpendicular ?
( Imagine that you are trying to explain what you just said to someone with the mental capacity of a child ...... or a very smart monkey . )
01-30-2010, 10:47 PM
Well, if you get a crosswind on a sailboat, and increase the sail area, it goes faster. Most of the rigid-wing sailing cars have not had a way to adjust for right or left crosswinds. I saw Mana La get hit by a gust, and the acceleration was obvious. Second Inning: Mana La Solar Car Put On Display At Peterson Automotive Museum - Green Diary YMMV
The Following User Says Thank You to Bicycle Bob For This Useful Post:
01-30-2010, 10:50 PM
T-100 Road Warrior
I'll show you mine...
The Following User Says Thank You to BamZipPow For This Useful Post:
01-30-2010, 11:03 PM
#10 (permalink)
T-100 Road Warrior
Originally Posted by puddleglum
Fixed yer links...
