Old 10-24-2009, 03:02 PM   #1 (permalink)
for(cD i=.25;i>.16;i--)
UltraHatchy - '00 Honda Insight 5spd
90 day: 63.55 mpg (US)
Deep cycle batterys, solar, amp-hours. question.
So I've located two L16 deep cycle batteries that, when new, claimed 340ish amp-hours @ full charge. They were taken out of commission but were part a large home array that didn't age the same. They are in good shape. I left the cooked ones alone. An electrician and I tried hooking an amp clamp to the positive pole of the battery with the car on, engine running, and everything (defroster, fan, radio, flashers, hlights, brakelights, everything) on. At the highest draw, the amp clamp was reading 3.7 amps. It may have been funny since it was possibly an exclusively AC amp clamp. Does anyone have reading from their vehicles that can back this reading up or for sure say that it's in error? I have a '97 civic hatchback dx.
My hope is to take the alternator belt out off of the engine, put the big batteries (320 lbs for the two of 'em) in the back, and run the car off of them, charging them with solar, and get some significant MPG gains.
I'll probably include a plug to hook up to since I live in new england and the sun can make itself scarce.
Any other pointers, comments, etc?
Old 10-24-2009, 04:14 PM   #2 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Amp clamps only work on AC. That's one scary electrician.
Old 10-24-2009, 04:18 PM   #3 (permalink)
To his credit, he was skeptical that the reading would mean anything. Is there a way to comput the reading from an AC amp clamp to a meaningful value for DC? It did reflect increases and decreases when turning thing like lights, defrosters, ect on and off.
Old 10-24-2009, 04:21 PM   #4 (permalink)
McTimson's Avatar
Maverick - '22 Ford Maverick XLT
90 day: 40.02 mpg (US)
320lbs is a lot of weight, which will offset the gains of not having the alternator on. I'm not sure how much it will offset it by, but the weight will probably be noticeable.
How long is your commute, can you get away with only using one of the batteries?
And yes, that is definitely not right, 3.7A is like 45W, which is about what one headlight draws, let alone the entire car.
Old 10-24-2009, 04:24 PM   #5 (permalink)
The batteries are 6 volts each, so I need 2 to get to 12 volts so the car can use the power. The electrician said that there's no way of halving the amp-hours and doubling the voltage or something like that, and that I'd need both batteries to get useful power.
Old 10-24-2009, 04:27 PM   #6 (permalink)
No, the meter was reading the variations in draw, not the flow itself. Most cheap multimeters will have a separate setting for up to 10A, but be careful about overloading them. For small-draw items, you can take out the relevant fuse, and put the meter probes across the terminals instead. A cheap dash ammeter will give a rough reading for suspected heavy draws.
Old 10-24-2009, 04:33 PM   #7 (permalink)
There's another thread around here that says that you need 14v to keep most of the car happy - as if the battery were on charge. The type of rig that boosts 12 to 14 can also do 6 to 14. The indiglo light in my wristwatch runs on 100V!
Old 10-24-2009, 04:42 PM   #8 (permalink)
Hall effect sensors also work on DC. Inductive sensors only work on AC. It must be a cheap probe since all the good ones use Hall effect for higher accuracy on non-sinusoidal waveforms.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
The Following User Says Thank You to NiHaoMike For This Useful Post:
Bicycle Bob (10-24-2009)
Old 10-24-2009, 04:48 PM   #9 (permalink)
Could, then, the error have come from not disconnecting the alternator while doing this test?
Old 10-26-2009, 07:41 AM   #10 (permalink)
micondie's Avatar
moby van - '03 Dodge Caravan SE
90 day: 19.74 mpg (US)
I would think twice about adding 320 pounds of battery (plus mounting hardware strong enough to keep those batteries from getting loose in a accident!!) in a 2400 pound civic. That is at least a 13% weight penalty and it's not like your mother-in-law in the back seat occasionally, it's all the time! No alternator delete is going to make up for that.
Replacing alternator with solar panel array on roof? blackjackel EcoModding Central 91 01-19-2012 09:19 PM
any 4.0 jeep guys on here? do the deep cycle battery? 95CHERJUST General Efficiency Discussion 2 10-13-2008 10:20 AM
