Originally Posted by oldbeaver
Hello Mach4,
Sounds interesting. But, I dont understand well your system, as the engine uses less fuel than the one received from the IP. Then the floating thing bowl may explode with fuel... or not?
Please, can you make a draw or a diagram of it?
This should help.
First, here is a diagram of a typical carburetor. The float bowl allows new fuel to flow into the bowl at exactly the same rate as fuel is used by the engine. This is necessary as air flow across the venturi creates a vacuum which pulls fuel out of the float bowl proportional to the flow rate and atomizes it for use in the engine. A constant head pressure is necessary (or fuel flow would vary) hence the use of the float bowl to maintain a constant level.
In the system I was describing to allow the use of a single flow meter, the float bowl is removed from the carburetor and mounted stand alone using an aluminum backing plate. Two fittings are added to the float bowl, one for fuel to the engine and one for fuel returning from the engine.
It is impossible for the engine to return
more fuel to the tank (or in this case float bowl) than the engine receives from the tank. If this were not the case, we would have a perpetual motion machine where the tank would continually [magically] be filled by the engine. Our gas stations would be places we would dump excess fuel rather than refueling.
The float bowl needs pressure to fill so a boost pump is needed somewhere between the tank and the float bowl. The lift pump on the engine would then pull fuel by vacuum from the float bowl to the IP.
Just for reference, here is what a Holley float bowl looks like.
![](http://ecomodder.com/forum/attachment.php?attachmentid=16164&stc=1&d=1413763812)
