Old 06-03-2009, 12:09 PM   #11 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
It is a brace, for those wobbly front control arm mounts on metros and rabbits and lots of other unibody cars. It's most noticable under braking if your car temporarily goes into a toe out situation but helps keep the tires pointed in the right direction under cornering and hard acceleration as well.
It's $2, just try it LOL
Old 06-03-2009, 12:12 PM   #12 (permalink)
QuickLTD's Avatar
Flying Brick - '96 Pontiac Bonneville SE
90 day: 23.57 mpg (US)
Send a message via AIM to QuickLTD Send a message via Yahoo to QuickLTD
Unibody chassis "flex" and move under stress/cornering/offroad excursions and just regular driving. In therory the suspension mounting points take most of the load. Anything that can tie the stress points together can reduce movement and make the handling more predictable. At the same time it should make the ride better especially on an older car that has softened up.
1996 Pontiac Bonneville SE 3.8L V6
Old 06-03-2009, 06:12 PM   #13 (permalink)
Thanks All of you, I Knew this was the right place for an education
Old 06-04-2009, 10:42 AM   #14 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
I'm jotting down a note to head to home Depot this weekend and make me a stress bar.
Old 06-08-2009, 02:06 AM   #15 (permalink)
Great Mod! I will give this a try.
Old 06-08-2009, 10:44 AM   #16 (permalink)
Ecomod noob
zjrog's Avatar
ZJ - '95 Jeep Grand Cherokee Laredo Upcountry
90 day: 20.57 mpg (US)
Neon - '03 Dodge Neon SE
90 day: 33.46 mpg (US)
S'Crew - '02 Ford F150 Supercrew XLT
90 day: 16.4 mpg (US)
Ranger - '90 Ford Ranger
Last 3: 28.02 mpg (US)
Not the Jeep - '03 Dodge Neon SE
90 day: 34.11 mpg (US)
I'll have to agree, a "stress bar" is a great idea, lots of folks (in other motoring communites) use them. I'm just not real comfortable with conduit as a finished material. I've used conduit for getting shapes right to bend tube. But can't imagine using it in high stress points.
When it comes to Heroes, RENEGADES are mine!
Old 06-08-2009, 01:00 PM   #17 (permalink)
dcb
needs more cowbell
dcb's Avatar
Rough guess I've got 1200 foot/lbs into that bend. Since the holes only have inches of offset to work with it should be able to add several thousand pounds of reinforcement.
The small cars seem to like it, minimal tools required, straighter = better of course.
Old 06-08-2009, 09:57 PM   #18 (permalink)
Ecomod noob
zjrog's Avatar
Ya gotta remember, I'm a Jeep guy, offroader. Overkill is just about right...
Be sure though, to let us know if the holes elongate after a couple thousand miles. For your purposes it shouldn't.
