View Poll Results: All else being equal, does fuel brand affect FE?
Yes, significantly 17 21.79%
Yes, but not by a significant amount 27 34.62%
No, there's no significant impact 34 43.59%
Voters: 78. You may not vote on this poll
Old 10-03-2012, 11:14 AM   #1 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Do you think the brand of fuel makes a difference
This poll was inspired by this post by TheIVJackal:
http://ecomodder.com/forum/showthrea...her-23527.html
The question is: All else being equal, for the vehicle you most often drive, do you think the brand of fuel (BP, Shell, etc.) has an impact on fuel economy? By "all else being equal" I mean same grade, as well as same content (E0, E10, E85, etc.).
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Old 10-03-2012, 12:10 PM   #2 (permalink)
2000neon's Avatar
VX - '94 Honda Civic VX
90 day: 47.95 mpg (US)
I think no. At least in the few times I have used different brands I have never seen a difference.
Old 10-03-2012, 12:26 PM   #3 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Only if the octane or ethanol content is different too.
I'm not coasting, I'm shifting slowly.
Old 10-03-2012, 12:35 PM   #4 (permalink)
Always Too Busy
Flakbadger's Avatar
White Lightning - '17 Nissan Leaf SV
Team Leaf
90 day: 159.47 mpg (US)
Maybe it's just bias, but Arco's gas has made my car(s) run like s*** when I've used it. I usually fill up at the Chevron on the corner because it's less than a block away.
Nissan Leaf driver? Join me in Team Leaf and feel smugly superior about our MPGe
Current Car: White Lightning
Retired Car: Betty White
Old 10-03-2012, 12:47 PM   #5 (permalink)
90 day: 19.36 mpg (US)
I voted "yes, but not quite significant [enough to chase it down]". Diesel can vary in quality and is prone to in-ground tank problems (not just vehicle tank problems, mainly algae). High volume retailers are best, overall.
I've had enough commercial operators tell me that SHELL has better quality diesel. That, plus EXXON are my first choices when solo. Towing I just use truck stops where the "tax problem" (different states) means that private vehicles can use the big truck pumps.
Overall, I don't buy from WALMART or the same. I want the best additive package for fuel, gasoline or diesel. That others do is their concern.
Old 10-03-2012, 01:20 PM   #6 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
I have noted different stations selling fuels with different amounts of alcohol and different octane values as regular at the same price in the circumstances where ethanol content varies from one station to another it does make some difference, but I doubt the additive package makes much difference.
Oh and Arco used to sell gasoline in the early 80's that had a small amount of diesel fuel mixed in right at the pump, claimed it boosted fe.
Old 10-03-2012, 04:56 PM   #7 (permalink)
...beats walking...
People seem to forget that MOST all gasoline is "piped" from refinery location to distribution location in a SINGLE common pipeline...shared by MANY different (and often competing) companies.
One has to wonder about the "purity" of all those gallons of gasoline during "startup" and "shutdown" transitions between different blends and companies.
Old 10-03-2012, 07:41 PM   #8 (permalink)
Yeah buddy, many of the newer insight owners have seen a 5 mpg change from bargin to name brand gas, wawa vs BP. I see the car handles more timing and isnt as droning from the exhaust on mid grade, but not enough to be cost effective to go to mid vs regular unleaded.
I too see a similar difference when buying gas from a county station vs city, ethanol content change. May contain up to 10% to contains 10% ethanol.
Old 10-12-2012, 06:45 AM   #9 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
The only proven difference exists with so-called premium fuel-efficient diesel fuels in Europe.
The difference is up to 3% - with Total Excellium Diesel - but not all brands can match that number.
The price difference, is WAY above those 3%, so all these fuels are uneconomical to use.
Old 10-15-2012, 09:12 PM   #10 (permalink)
I compared Speedway to BP. . .
A few years ago I was commuting 180 miles a day in a Silverado that got 18MPG so I was burning 10 gallons of gas per day. That can lead to desperation at the pump. At that time Speedway was usually 5 cents per gallon less than BP so I was buying it regularly. I decided to see if the BP was worth the extra money or not. I logged each tank and only compared tanks used only for commuting, no weekend in-town driving. After I had 10 tanks of each I found that the cost of the BP was 1.6% more but the mileage was 8.3% better.
Not all engines respond the same, my Impala doesn't seem to have a preference, at least not that I have found yet.
The Following User Says Thank You to rbrowning For This Useful Post:
wwkayaker (11-07-2012)
