Old 12-26-2013, 06:00 PM   #21 (permalink)
I believe hybrid revolt sells something like that for the older gen insight. The 2nd gen insight does this in eco mode.It numbs the throttle and cruse control so it is delayed, but further usage it does pick up its response.
Old 12-28-2013, 08:31 AM   #22 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
I really need to find someone to tune up my cobalt this way, it has the same exact problem, 20% throttle gives you 95%+. A light touch and the rpms rev up to 2500 in neutral, impossible to rev match correctly due to the poor control.
Old 12-29-2013, 12:11 PM   #23 (permalink)
where are you in WI? I tap my throttle to rev match, and it works great. I also had trifecta remove the throttle lag, so fine control of the throttle is more predictable and actually seems at least more progressive.
Old 12-29-2013, 04:15 PM   #24 (permalink)
rmay635703's Avatar
I travel between Weston and Oshkosh most every week
Old 12-29-2013, 09:41 PM   #25 (permalink)
one thing I've noticed in general since the move from carburetors to fuel injection is the throttle pedal is more touchy.
Old 12-30-2013, 12:55 PM   #26 (permalink)
XJ Cherokee - '00 Jeep Cherokee Sport
90 day: 12.96 mpg (US)
FoFO - '11 Ford Focus SE
90 day: 36.78 mpg (US)
There are at least 4 different programs on my Focus. It's hard figuring out which one it will be using.
On some drive by wire systems (chrysler) it's horrible.
Old 01-14-2014, 12:50 PM   #27 (permalink)
ECOModder
Mr. Previa's Avatar
RAV - '13 Toyota RAV4 XLE AWD
90 day: 27.56 mpg (US)
Smile
Interested thread. I don't seem to have that issue with my '13 RAV4. On a note, it does have the ECO/Sport buttons.
I also had a 2010 Prius. It was very smooth also. I even converted it to a plugin and it performed well in regards to the "surging" and pedal response. hmm, if memory serves me right the Prius also had the ECO/Sport buttons.
Perhaps manufactures, at least Toyota, are paying attention to this. IDK...
3585 pounds of twisted steel.
Recreational | Active | Vehicle | 4x4
...scratch that... AWD
Old 02-13-2014, 09:45 PM   #28 (permalink)
ever_green's Avatar
gueff - '19 Mercedes Benz A250 4MATIC AMG
90 day: 30.55 mpg (US)
Now that the throttle has been tuned to perfection, I have moved on to other things like tuning fuel and timing. I have already increased part throttle timing without issues and now have been looking at idle timing. I was wondering what effects ignition timing has at idle and coasting on fuel economy? I have read lower timing during fuel-cutoff/coasting means less engine breaking. If so this is a good thing for fuel economy purposes? My current timing is set at 15* at idle and up to 30* when coasting at speed. For some reason the manual (5-speed) ECU calls for only 9* of timing at low RPM idle. Why the difference?
Idle Ignition Timing Table
as for fuel I have not been able to induce lean burn. Lowering values above 0 simply just sends the car to open loop. However I have managed to replace it with leaner numbers. This is how the fuel map looks like:
closed loop fueling table. To calculate AFR subtract from 14.7. Ie. -0.1 means 14.6:1 AFR. I simply replaced all values at lower RPMs with 0 to run at 14.7.
Old 02-14-2014, 10:29 AM   #29 (permalink)
It been long time since i messed around with timing curves .
things to watch out for If my memory is still good . high timing in low rpm/load can increase emissions . whats in your chart doesn't seem to bad at low speeds (500-1500 ).
What was the stock values .
Manual model will have no load at idle vers auto is always in gear so can handle slightly more timing , I think the curves are mainly influenced by emission output then performance .
Old 02-14-2014, 10:44 AM   #30 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
There was talk in another thread of having the throttle open when fuel injectors are cut off. Resulting in less pumping losses and able to ride DFCO longer. Would that be something that is programmable?
The Following User Says Thank You to brucey For This Useful Post:
kyanox (04-11-2016)
