Old 06-27-2008, 03:06 PM   #1 (permalink)
1997 Civic POS - '97 Honda Civic EX
90 day: 33.29 mpg (US)
Send a message via AIM to ajax_6531 Send a message via Yahoo to ajax_6531
E85 in a non flex-fuel vehicle
What are the pros and cons to running a non flex-fuel vehicle on E85?
As of now, I don't even know if I can get it in my area. I'm just wondering what I should expect to see.
Thanks
IYAOYAS
Old 06-27-2008, 05:58 PM   #2 (permalink)
Straight E85 in a non flex-fuel vehicle will possibly throw the check engine light. In warm weather when the engine is warmed up it will run fine even if the dang light is on, although it probably won't give you full power at wide open throttle. That doesn't stop me from doing straight E85 fills for three seasons, cuz I don't use WOT. The colder it gets, especially sub-freezing, the more it doesn't want to start right up. On straight E85 I notice a drop in fuel economy, but not as bad as many people claim.
I have found, on my stuff, that a 50/50 E85/regular (which is E10 here) mix avoids just about everything I mentioned above- no CEL, WOT power, and also no loss of fuel economy. Last winter I did get in trouble with E85 in below zero temps. I don't remember how strong my fuel mix was but in the future I am going to stay away from E85 when I think it'll get below zero.
I have had no problems running my 14 and 16 year old vehicles on E85 for the last 3 or 4 years. No bad injectors, no plugged filters, no disintegrating lines or pumps. Some people claim E85 causes all these problems. Well I know what kind of luck I usually have, so it's not that I'm lucky.
The Following 2 Users Say Thank You to Frank Lee For This Useful Post:
B440 (12-20-2013), Cd (04-05-2012)
Old 06-27-2008, 06:01 PM   #3 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse (retired) - '97 Iron horse Intrepid
Ninja - '08 Kawasaki 250R
90 day: 76.23 mpg (US)
I'm with Frank on this. I've run varing mixtures from E10-E85 although mostly E20 for 2 years no problems and better FE. The cars are 1999 or newer.
"Judge a person by their questions rather than their answers."
Old 06-28-2008, 12:08 AM   #4 (permalink)
pontiac trans am - '00 pontiac firebird trans am
jeep 1 - '02 jeep wrangler
90 day: 16.76 mpg (US)
jeep 2 - '07 jeep wrangler x
90 day: 19.39 mpg (US)
Toyota - '09 Toyota Corolla lx
it varys depending on the vehicle, some vehicles have worse results than others, for instance my dads 98 cavalier runs like dookie with e85 while some other vehicles will notice no real difference. it is worth checking out, most of the "negatives" associated with e85 are either myths or blown out of proportion.
Old 06-28-2008, 12:35 AM   #5 (permalink)
Liberti
LostCause's Avatar
Thunderbird - '96 Ford Thunderbird
90 day: 27.75 mpg (US)
Does anyone know the octane rating of E85? It might be cool to build a high compression motor to get the best of both worlds: higher FE and cheaper fuel.
- LostCause
Old 06-28-2008, 09:03 AM   #6 (permalink)
according to this article on wikipedia it is 105
Octane rating - Wikipedia, the free encyclopedia
Old 06-28-2008, 11:27 AM   #7 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 Scion xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
- LostCause
When I first had a Subaru, I read the NASIOC forum, and there were guys with WRXs who experimented with E85, and concluded that it's great if you tune for it. Since it's equivalent to very high octane gasoline, it allowed really high boost pressures. Of course, for the Subaru WRX and STI, there is available an ECU-tuning device, so you can switch between modes optimized for different fuels, boost, etc., so it is relatively safe.
As an aside, if anyone is running a Yaris/Echo/Prius/xA/xB (they all have the same engine, except the Prius has different cams and timing, essentially) on E85, I'm curious to hear how it works out. I can't get it here, either, but I'd like to know.
Old 06-28-2008, 01:13 PM   #8 (permalink)
Ecomod noob
zjrog's Avatar
ZJ - '95 Jeep Grand Cherokee Laredo Upcountry
90 day: 20.57 mpg (US)
Neon - '03 Dodge Neon SE
90 day: 33.46 mpg (US)
S'Crew - '02 Ford F150 Supercrew XLT
90 day: 16.4 mpg (US)
Ranger - '90 Ford Ranger
Last 3: 28.02 mpg (US)
Not the Jeep - '03 Dodge Neon SE
90 day: 34.11 mpg (US)
I have seen fuel rails corrode through due to E85. But my friend ran straight E85 in his non flex fuel 94 Acclaim. I thought the car ran OK most of the time, though it did have some stumble issues now and again. That turned out to be a couple injectors leaking. Was it the E85? Don't know.
When it comes to Heroes, RENEGADES are mine!
Old 06-29-2008, 05:06 PM   #9 (permalink)
'07 Saab 9-3 Sedan 2.0T S
Krieg's Avatar
Guys, I've been running E85 in my non-flex fuel Saab since March. I'm documenting my experience in a blog:
www.drunkenswede.blogspot.com
The biggest problem with E85 is simple its availability. I'm lucky that I live behind a Meijer. They sell E85 at this location.
Running E85 in a non-flex fuel '07 Saab 9-3 2.0T
Old 07-08-2008, 02:16 PM   #10 (permalink)
MR2 - '93 Toyota MR2 Turbo
90 day: 22.92 mpg (US)
Send a message via AIM to Blue Bomber
The high percentage of ethanol in E85 can destroy certain hoses and seals in your fuel system. At the minimum, you should replace your fuel lines with an E85-compatible material to prevent major leaks. Your fuel pump and injector O-rings may also need to be upgraded in order to ensure full compatibility.
Fuel Economy related papers tasdrouille General Efficiency Discussion 41 03-19-2021 06:31 PM
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 29 09-06-2018 03:09 PM
Diesel- and Hybrid-Powered Vehicles Can Provide More Societal Benefits than Gas-Power SVOboy General Efficiency Discussion 12 04-29-2017 08:03 AM
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 10:35 AM
