Old 06-25-2011, 09:28 PM   #1 (permalink)
Electric Airplanes
Here's one electric airplane:
(click on image for link)
Here's another:
(click on image for link, including video)
Old 06-25-2011, 10:08 PM   #2 (permalink)
...beats walking...
...I can just see it now--a stewardess frantically running up & down the isle asking passengers if anyone has any spare BATTERIES whenever their airliner has to go into a "holding pattern" around a busy airport!
Old 06-25-2011, 10:48 PM   #3 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
what is the effect on weight and range and power?
Oh, wait, it is a tiny fraction of liquid fueled, like so many electric cars that go 40 miles. I bet it costs a fortune too. They can have it put out the same power for a tiny fraction of the range or some other combination of a fraction of liquid fuel capabilities.
There's lithium, right next to ZERO on energy/mass and energy/volume...
Old 06-25-2011, 11:44 PM   #4 (permalink)
Somehow I doubt that :-) Even if electric airliners someday become practical - well, does the cabin crew run around asking passengers if they happen to have any jet A on them when a flight goes into a holding pattern nowadays?
Even now, there are places where electric airplanes could work, starting with (as mentioned on that other thread) self-launching sailplanes. Then there are possibilities in the Light Sport class, where you may never travel long distances. When you figure that 100LL avgas is now $7.09/gal at my FBO (plus a quart of not-cheap aviation oil every 10 hours or so), and that a major overhaul of an aircraft engine was IIRC about $12K over a decade ago (about $16K now, from a quick search), electric power for sport flying begins to look kind of attractive.
Then too, as with the Tesla, there are people to whom the impact, environmental & otherwise, of burning oil is more important than money.
Old 06-26-2011, 12:30 AM   #5 (permalink)
dude...wait...what?
Odin's Avatar
Diesel Rx-7 - '82 Mazda Rx-7 GSL
merc 300d - '82 Mercedes-benz 300d dt
b2200 diesel - '84 Mazda b2200 D
I'm pretty sure that chart is taking the energy of a lithium ion battery its self, not one fully charged with electricity.
82 rx7 diesel
82 300d diesel
84 b2200 diesel
All veggie, all the time!
Old 06-26-2011, 05:56 AM   #6 (permalink)
Chug - '96 Volkswagon Polo CL
90 day: 49.42 mpg (US)
L'Autre - '03 Renault Megane Sport Tourer Expression
Diesel
90 day: 45.02 mpg (US)
My Li-Po race cels are lighter than my Li-Fe's and you've got to remember with electric there would be little differential between take-off and landing weight and you could dump all the fuel pressurisation/cooling sytem just think of the turn around time if it was a cell exchange at each air port rather than a charge!
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
Old 06-26-2011, 07:30 AM   #7 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
electric power has taken over in the remote control airplane hobby
Nissan Versa Aeromods
Old 06-26-2011, 10:53 AM   #8 (permalink)
dcb
needs more cowbell
dcb's Avatar
Not sure why you think that. Can you offer any supporting evidence?
per: Lithium-ion battery - Wikipedia, the free encyclopedia
Volumetric energy density: 250 to 620 W·h/l (900 to 1900 J/cm³)[2]
1000 cm³ = 1L
~2MJ/L energy density for lithium batteries, which is about what was plotted, compared to ~37MJ/L for diesel.
Originally Posted by robchalmers View Post
...with electric there would be little differential between take-off and landing weight..
That is another disadvantage of electric plains, the batteries still weigh a ton when they are depleted, whereas your fuel tanks do not. Dead weight on a plane translates into inefficiencies, you have to create more lift, which doesn't come for free.
...just think of the turn around time if it was a cell exchange at each air port rather than a charge!
Great, just make sure the airports are spaced 10 miles apart so you can make it to the next one
Indeed, such toys, that have no need for payload that run for maybe 10 minutes (well I usually catch a thermal or two also), do not need to be uber efficient. There are still a lot of fuelies left when the pilot is serious about performance.
As an aside, excellent performance can be had with NO motor too (and extra weights are usually needed), though around here I just bungee launch:
Old 06-26-2011, 11:19 AM   #9 (permalink)
dcb
needs more cowbell
dcb's Avatar
What I find funny about that video is the RC jet guys are lucky to push 360mph
. Maybe you get 200mph with an electric RC, and the no-motor plane serves them both up for raw top speed (and endurance and efficiency and cost) under the right conditions
Old 06-26-2011, 11:50 AM   #10 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
At least at my local air port most people with small private planes don't take them on long trips and that plane has a 140 mile range, so you are good for a trip to a cabin or taking someone on an air tour of the area and the best part is, if you have your own air strip... straight section of road or field, you don't need to get fuel deliveries there any more, you just need a 220v outlet.
It also sounds like these planes cost about the same as the gasoline counterparts but are much simpler so when you get your annual inspection done you get your electric motor checked and maybe bearings replaced compared to a gas engine plane that gets it's engine tore down and rebuilt.
