Old 01-12-2017, 05:06 PM   #31 (permalink)
Jack-Lee's Avatar
Partygurke - '90 VW Polo 2F
Rodi - '04 Smart Roadster Coupe
And now i build up the new controller. A "UMC1". Sensors: MAF (main), MAT, CLT,TPS,Lambda.
The Following User Says Thank You to Jack-Lee For This Useful Post:
Logic (10-01-2022)
Old 01-17-2017, 05:18 PM   #32 (permalink)
Jack-Lee's Avatar
Now i modified the head of the motor.
I would build in 29mm/32mm valves with 6mm stem in place of the 28/32mm original valves with 8mm stem. In addition i mill the valve seats to the max for much intake/exhaust flow.
I turn my own valve guides, from CW713R, because theres no guides with 6mm inside and 12,06mm outside on the market. Besides i smoothed the ports and makes the radius as great as possible. So i could realise a 25% better cfm rating.
The intake manifold merge to the head and i install the big throttle from the 75PS GT Engine.
And for better comparability i make a dyno-test with the original Engine:
http://network.perfexpert-app.com/results/WsfkuKAXrW
Old 01-20-2017, 04:37 PM   #33 (permalink)
Jack-Lee's Avatar
Another work is done: The Valves are ready.
Intake Valve 35% lighter and more aerodynamic
Exhaust Valve 40% lighter.
ID:	21207   Click image for larger version
ID:	21208   Click image for larger version
ID:	21209   Click image for larger version
Old 01-21-2017, 01:36 PM   #34 (permalink)
90 day: 30.18 mpg (US)
Is the only difference between the dyno tests the valves?
Old 01-25-2017, 03:49 PM   #35 (permalink)
Jack-Lee's Avatar
No, the three dynostests made directly in a row. Minimize deviation.
The new Valves, the MPI and the modified head should rise the power from 45hp to 80hp and the torque from 77Nm to 115Nm
Old 01-25-2017, 05:49 PM   #36 (permalink)
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
Nice work.
You focus on exhaust valve to reduce pumping losses ?
Good to know someone who cuts their own valve guides ;-)
Old 01-28-2017, 03:01 AM   #37 (permalink)
Jack-Lee's Avatar
I change all Valves. So i could reduce the weight, could work with ne single spring (instead of two) and improve the airflow.
Yesterday i build the elektronik. Works great (on the Table), today i build it in the car.
ID:	21248   Click image for larger version
ID:	21249   Click image for larger version
Old 01-30-2017, 05:00 PM   #38 (permalink)
Jack-Lee's Avatar
Today the car is ready to roll.
Old 02-09-2017, 01:31 AM   #39 (permalink)
Jack-Lee's Avatar
Oh, i forget to upload the results of the mod with the new fuel injection
Nice Tourqe und Power-gain. Now i musst build up the new head and install it.
Old 02-17-2017, 11:41 AM   #40 (permalink)
Jack-Lee's Avatar
Now the valve-set is complete Ready to install.
I could manage 33% less weight and 20% more flow.
ID:	21305   Click image for larger version
ID:	21306   Click image for larger version
ID:	21307   Click image for larger version
ID:	21308   Click image for larger version
ID:	21310   Click image for larger version
ID:	21311   Click image for larger version
