Old 02-15-2014, 04:54 PM   #71 (permalink)
XPedro, if you had the room, I would say that you needed to install a fighter-jet-style joystick, just to make it look like a cockpit!
"Woah! What does this do?!"
"It turns on the windshield wiper."
"Oh..."
xpedro01 (02-16-2014)
Old 02-16-2014, 02:28 PM   #72 (permalink)
[QUOTE=xpedro01;411387]Xist;Thanks, you proved it can be done.
When l try, l get this;
XPedro, I should have mentioned that you need to make sure to remove the "http://" when you post the address. When I paste, it replaces that with my address. Right now you have "[IMG]http://http://"
I hope that helps!
Eta, I apologize for going off-topic!
Old 02-17-2014, 10:48 AM   #73 (permalink)
xpedro01
xpedro01's Avatar
1-The one on the left is the original. It is a 2012 "icebear magnum",300cc,liquid cooled, auto transmission,chain drive, 1f-2r trike.
2.-After destroying a perfectly usable machine. The materials used are .063" aluminum and 063" lexan. Lexan is a super friendly plastic. Try torturing a DVD disk.
3.-It worked ok even after changing the drive sprocket, from 19 tooth to 29 tooth (52% overdrive) but l was uncomfortable in cross winds. This led to a complete reworking and lowering 14 inches. This called for rebuilding body, frame, and wiring.
4.-This is the shape of the belly pan. It is 36" wide and 96" long.
ID:	14649   Click image for larger version
ID:	14650   Click image for larger version
ID:	14651   Click image for larger version
Old 02-17-2014, 11:34 AM   #74 (permalink)
xpedro01
xpedro01's Avatar
5.-Here is the ventilation system. You can see Mustang radiator cooling fans. The back is open. Air is drawn in from the cut out for the front wheel and exhausted with these fans. Because the operator sits in front of the engine l felt it needed exhaust fans, and it also has a carbon monoxide detector.
At the moment I am putting my free time on my baby Honda Insight 2000 MT. After finishing its mods I plan to continue on the trike. The Honda is necessary--the trike is a mileage thingy.
Old 02-17-2014, 11:55 PM   #75 (permalink)
iveyjh's Avatar
none - '98 Honda Civic HX
none - '00 Chevy (Geo) Metro base
none - '00 Saturn SL1 base
You do nice work.
The Following User Says Thank You to iveyjh For This Useful Post:
xpedro01 (02-18-2014)
Old 02-18-2014, 09:18 AM   #76 (permalink)
xpedro01
xpedro01's Avatar
Thanks-iveyjh-I see where you have put an extension on a vehicle. I also added 16" on the tail of my 2000 Insight MT. It looks like a 5% GAIN. The link is;
http://ecomodder.com/forum/showthrea...5-a-28088.html xpedro01
Old 02-18-2014, 11:02 AM   #77 (permalink)
iveyjh's Avatar
Thumbs up
That's just some coroplast work, nothing up to your level of expertise.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
Geo Metro XFI Convertible Project Finished Coyote X EcoModding Central 227 11-14-2009 10:31 PM
New: Ford mods their Super Duty pickups ... chin spoiler + final drive changes MetroMPG EcoModding Central 1 01-08-2008 01:32 PM
DIY - Head Swap (Project KDA complete!) SVOboy DIY / How-to 16 01-03-2008 02:17 AM
Article: Larger, yet more fuel-efficient than before. (What the...) MetroMPG General Efficiency Discussion 0 12-14-2007 06:18 PM
