Old 11-11-2020, 01:02 PM   #11 (permalink)
Similar to above, I had a programable t'stat that plugs into an outlet (or cord) and used it in cool mode to turn on a fan pointed at the wood stove when I had one.
I think it was Lux lasted quite a while in a pretty hot environment beside the stove even with an fan blowing near it.
Old 11-12-2020, 02:36 PM   #12 (permalink)
Permanent Lurker
seifrob's Avatar
Dáčenka - '10 Dacia / Renault Logan MCV 1.5 dCi (X90 k9k)
90 day: 47.08 mpg (US)
Just my two cents:
- fans at bottom, leave the rest open.
- This setup (four inches space between stove and wall is meant as fire precaution. Any restriction of free airflow and you made a hot chamber behind all the decorative finish. It is compromise between aesthetics and functionality.
EDIT - i didn´t read its a gas stove, so never mind, it has probably some sort of fire protection...
- wire protection covers (salvaged from PSU or bought separately - something like that: https://www.amazon.com/Easycargo-Gri...FXDP14FFV3CMAY) do not restrict airflow and add ton of finish.
I fabbed something similar for my parents wood stove with four 12-cm PC fans and no thermostat, just PWM speed control module (cca $3.90, e-bay) to controll it manually. (Unfortunatelly my mother is more for aesthetics and does not like to mix "country" with "techno", as she said)
If you want to go redneck style, get temperature controlled switch from old electric kettle. Closes/opens at boiling point.
Sounds like nice project to me!
P.S: If you want no project, just 100% style, go for this: https://www.ecofan.co.uk/
or this: https://www.stirlingengine.co.uk/d.a...VULCANSTOVEFAN
(there are also cheaper e-bay versions, but afaik these are the originals)
- you could try thermocouple modules to power your CPU fans... No need to control, runs when your stove is hot enough... - get inspired by that ecofan
Old 10-31-2022, 01:20 PM   #13 (permalink)
90 day: 29.78 mpg (US)
Well, 2 years later and I'm getting closer to actually implementing this idea. This weekend I mocked up the fans using double sided tape, wired them together, and tested operation using my switching power supply.
I had to remove the igniter from the mount because it was hitting the fan, but this setup seems to be best. I'll run screws into the grate to secure the fans.
I'll use the temperature switch from the squirrel cage blower to activate the fans, and a 12v AC adaptor I've got laying around. At 12v, 0.31 amps are drawn for just under 4 watts. These are way quieter than that noisy blower.
I will block off the sides using coroplast (maybe, unless I find something more heat resistant). It really isn't feasible to put fans on the ends.
Oh, that light in the ziplock bag is a WiFi switch so that the Chinese can control my fireplace using IoT. I've got Google starting the fireplace automatically during the morning routine. I had to become an expert on how the gas switches on and off electronically to get the right switch. Fireplaces that use a pilot light generate low voltage from that heat that is then used to open the gas valve when the switch is closed. I made the mistake of initially thinking regular house voltage was switched to activate the valve.
ID:	32976   Click image for larger version
Old 10-31-2022, 02:16 PM   #14 (permalink)
This reminds me, we haven't seen anything from Major Hardware's Fan Showdown in a month:
www.youtube.com/playlist?list=PLHLn2U7i45M_EXIsnqUyI-nqCCk-wfCU9
Old 10-31-2022, 02:31 PM   #15 (permalink)
I happen to have the fog machine at the ready for Halloween. Might as well use it to test airflow in the fireplace.
Old 10-31-2022, 03:44 PM   #16 (permalink)
The new managers realized the ground is laced with natural gas pipes, so they had them tested. Apparently I have Natural Gas available as a service.
I have 2-burner range, would I need a compressor for a car or a fuel cell for electric backup?
Old 10-31-2022, 05:51 PM   #17 (permalink)
Need my rusty BBQ? All burners still work, you just might need to light one of them by hand instead of the sparker.
Old 11-07-2022, 02:20 AM   #18 (permalink)
Finished a project. Squirrel cage blower seemed to throw the air everywhere. It takes 33 minutes after turning the fire off for the thermal switch to turn the squirrel cage blower off.
With my quieter 4 watt total, 120mm fans, it takes just 10 minutes to cool the heat box to the point the thermal switch opens. Seems like it's 1/10th the power, 1/10th the noise, and 3x as effective. Ima patent this when I get a round tuit.
I don't get why these fireplaces come with $200 ineffective blowers that are too noisy, when they could come with $20 worth of case fans that are way better.
I did have to drill mounting holes in the grill that are not externally visible to mount the fans. Then coroplast on the outside and duct tape to seal the small strip next to the fans.
EDIT: The fans are so effective that it can cool the heat box down enough that the thermal switch opens while the fire is on. This is something the standard blower was never capable of doing. Once the thermal switch turned on, it ran the fan until 30+ minutes after the fire was turned off.
I might even put a speed controller on there so I can turn the noise down even more, and that would put less cycles on the thermal switch.
freebeard (11-07-2022)
