Old 03-02-2010, 01:49 PM   #31 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Here are few finnish fuel economy related test reports:
http://www.motiva.fi/files/1027/2006..._eng_final.pdf
http://www.motiva.fi/files/950/annua...ng_07-rev1.pdf
http://www.motiva.fi/files/948/annua..._-2007_eng.pdf
Enjoy!
I will not save those on harddrive etc, but if someone is feels the need to do so please post links here...
The Following 2 Users Say Thank You to Vekke For This Useful Post:
aerohead (03-19-2021), ausias (03-01-2012)
Old 01-18-2011, 10:48 AM   #32 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Find a great source for free reasearch documents:
Free download pdf: truck drag reduction
Just write what you need and see what papers are available .
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following User Says Thank You to Vekke For This Useful Post:
Old 03-01-2012, 02:52 PM   #33 (permalink)
Burning oil to move air.
ausiasmobil - '06 Seat Leon 1.9 TDI Reference
90 day: 40.22 mpg (US)
EcoTxec - '99 Skoda Octavia 1.9 TDI 110 cv Laurin & Klement
90 day: 52.85 mpg (US)
maybe you could find complementary info refrent to Tire Rolling Resistance in:
http://ecomodder.com/forum/showthrea...-db-18989.html
Sold:
Old 03-06-2012, 12:22 PM   #34 (permalink)
...beats walking...
...2002 SAE paper on "Automotive Ignition Transfer Efficiency":
http://www.pulstar.com/pdf/TechPaper_SAE.pdf
Old 08-09-2013, 12:02 PM   #35 (permalink)
ever_green's Avatar
gueff - '19 Mercedes Benz A250 4MATIC AMG
90 day: 30.55 mpg (US)
a paper regarding effects of ignition timing, air fuel ratio and ethanol on brake specific fuel consumption and torque. This is good if you have a scangauge 2 and wondering what to do with the IGN (ignition timing) during acceleration.
http://www.sid.ir/En/VEWSSID/J_pdf/856200801B07.pdf
Old 09-02-2013, 09:58 PM   #36 (permalink)
An old paper pushing old ideas, one by Ricardo that ethanol can be efficient, if you tinker enough with a gasoline engine designed & built to burn 100% gasoline(ethanol-free).
Well, the many hundreds of millions(more?) of gasoline engines, designed & built to burn 100% gasoline, are still at their best when burning 100% gasoline..... no tinkering or expensive or time consuming modifications need apply.
This is NOT rocket science, but it is good 100% gasoline engine science.
Old 01-11-2017, 03:28 PM   #37 (permalink)
ScanGauge <3
ThermionicScott's Avatar
I saw the "Reduced Air Pollution ... with Pre-Heated Engines" paper mentioned in another thread, but it's no longer available through the link in the OP. If this is the same one, could the OP be updated? https://www.witpress.com/Secure/elib.../UT98035FU.pdf
Similarly, the "REDUCED COLD START EMISSIONS THROUGH USE OF ELECTRIC ENGINE HEATERS" paper can now be found here:
http://citeseerx.ist.psu.edu/viewdoc...=rep1&type=pdf
Best tank (so far): 32 MPG
Old 03-12-2017, 02:05 PM   #38 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
diesel engine optimization: http://lib.dr.iastate.edu/cgi/viewco...87&context=etd
Fingie (03-13-2017)
Old 09-10-2017, 12:48 AM   #39 (permalink)
Delivery 'Boy - '86 Suzuki Mighty Boy
90 day: 37.15 mpg (US)
SkipSwift - '13 Suzuki Swift GL
90 day: 35.44 mpg (US)
Hydrogen Loonies* will want to read this one
NASA on Gasoline/Hydrogen blends and changes in combustion
It goes through the benefits and total energy usage of hydrogen.
TLDR: Gasoline usage goes down, but total energy use goes up in most cases, and only gets low % better under ideal cases (not enough to counter hydrogen manufacture inefficiencies, they were using bottled hydrogen and not manufactured on demand), but combustion & emissions benefits are a real thing.
*I used to be a hydrogen enthusiast/loony. I even made my own very high volume electrolysis hydrogen generators. I kept a proper open mind though (not a 'the man hides this secret tech' open mind, the kind of open mind where you thoroughly explore the merits behind any given argument). This paper ended that particular fantasy, as it was able to confirm why I thought hydrogen should work, in a worst case efficiency scenario (most room for improvement), and all my theories were correct. They also had energy usage numbers that actually stack up, against HHO generation.
Originally Posted by Crazyrabbit
In God we trust. All others: bring data
Old 03-18-2021, 01:03 PM   #40 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Here is a graph I have not seen before
Sadly it emits any units so no comparison between with emissions equipment and without can be made, sadly the graph was made without EGR which would likely make a tremendous difference on the bottom graph going right
Can anyone find this WITH UNITS?
Source
https://bobistheoilguy.com/forums/th....339010/page-2
The Following User Says Thank You to rmay635703 For This Useful Post:
SuperMID - Fuel Economy Display SVOboy Instrumentation 25 05-15-2015 09:16 PM
How to calculate MPG / fuel economy formula MetroMPG DIY / How-to 29 11-25-2013 06:47 PM
What features on your ULTIMATE fuel economy instrumentation? MetroMPG Instrumentation 41 05-12-2012 01:14 PM
Why SUV fuel economy is so much more important than small car fuel economy... SVOboy General Efficiency Discussion 30 02-23-2009 06:26 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
