Old 01-02-2022, 12:28 AM   #1 (permalink)
has anyone built their own cng compressor
thinking of buying a $250 dollar scuba compressor (4500psi) on amazon to compress CNG for cars.
The CNG stations charge 1.60 / GGE, and homefill would be 30 cents per GGE.
The plan would be to have a flash back arrester on the intake to the compressor to prevent any accidents from going back into the main line.
Might also have a check valve to make sure the gas only goes one way.
It would appear impossible to have a flashback arrestor on the tank line due to 4500psi.
I havent been able to source cng service nozzles, i found fill ones but not the service handles like at the station, so i will be using a diy connector system that is rated for 4500psi, probably ball valves instead.
What u think of the plan?
The Following User Says Thank You to assistance For This Useful Post:
Isaac Zachary (03-02-2022)
Old 01-02-2022, 09:17 AM   #2 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Did you calculate how much cng you would need? And how many tanks you need to fill?
I had a look at those 250 compressors, the ones where you also attach a bucket of cold water. they are mainly for filling airgun tanks. So with such high volumes, i do not know how long they would last.
What car do you have?
Old 01-02-2022, 09:18 AM   #3 (permalink)
teoman's Avatar
A3 - '12 Audi A3
1m^3 is roughly 1l of liquid fuel.
A 10L scooba tank will hold 2000L at 200 bars. So 2 liters worth of fuel.
Old 01-02-2022, 10:57 AM   #4 (permalink)
I would research the project thoroughly before attempting it. Compressing natural gas sounds like a daunting venture in view of the potential for disaster and liability.
Old 01-02-2022, 02:42 PM   #5 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
At those pressures you would need supercompressibility calculations to more accurately determine how much energy you can put inside your tank.
However, (atmospheric pressure [absolute] + final cng pressure) ÷ (utility base delivery pressure [absolute]) = standard cubic feet per one actual cubic foot.
So a 1 cubic foot tank can store roughly 308 cf at 4500 psig.
I think what you're going to find is that to have a relatively safe and reliable system it will cost more money than it is worth.
Also, what are you going to do with the condensate?
Old 01-02-2022, 08:54 PM   #6 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
If it’s not rated for flammable gases I wouldn’t waste time on it, not worth explosions
The Following User Says Thank You to rmay635703 For This Useful Post:
hayden55 (01-03-2022)
Old 01-02-2022, 09:52 PM   #7 (permalink)
Things do fail in spectacular ways, luckily though for NG, it's basically inert above 15% concentration in air. If no oxygen is mixed, it's quite safe.
Old 01-03-2022, 08:55 AM   #8 (permalink)
Don't know about your specific community, but in many cities, they inject atmosphere into the natural gas stream in the winter to boost flow and pressure during the winter, typically below 10%. The utilities state this is quite safe and other than loss of range, the 3000 psi CNG bus I drove had no issues.
Old 01-04-2022, 07:57 AM   #9 (permalink)
Atmosphere? Like air? I've never heard of that in the industry but propane-air injection is fairly common. Though that is also being displaced by LNG.
Old 01-04-2022, 09:07 AM   #10 (permalink)
Yup: air consisting of whatever is at the input filter of the diesel pump. Have a friend that did maintenance inspections of them yearly all over the country.
