Old 04-21-2017, 07:33 AM   #11 (permalink)
Sheila - '13 Honda Insight EX
90 day: 33.08 mpg (US)
Janet - '14 Chevrolet Traverse LT
Last 3: 14.74 mpg (US)
Originally Posted by Daschicken View Post
You could make a quick and easy half tonneau cover with a sheet of plywood or coroplast. Cover the back half of the bed and leave the front open.
I realize this should be obvious to some degree but when you say the back-half, do you mean closer to the cab or to the bed's door?
Old 04-21-2017, 09:00 AM   #12 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
The truck's rear- the tailgate.
Transmission type Efficiency
Old 04-21-2017, 09:40 AM   #13 (permalink)
Eco Sol
Shortie771's Avatar
Welcome to Ecomodder. This is the most helpful group of people I've never met. There is plenty you can do to boost your FE. I'd say start with figuring out how to drive like a hypermiler first as it will take time to learn, but will also give you the greatest improvement over any mod you could do. If you want to do some mods, I would start with anything related to improving aerodynamics, because that's a big factor in your highway mileage.
Start here: 100+ Hypermiling / ecodriving tips & tactics for better mpg
You can find mods here: 65+ Vehicle modifications for better fuel economy
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
Old 05-31-2017, 09:28 AM   #14 (permalink)
justadude's Avatar
I know this is a bit late but welcome to the forums! This is a really great place, I'm sure you'll fit right in!
