Originally Posted by some_other_dave
I wonder if the resonator could be dynamically altered for different air speeds/conditions?
A range of tuning frequencies could be selected by telescoping the port, in a manner not drastically different from how a trombone is tuned. This is why I suggested using either a feedback system or a speed-based system for tuning such a device to its conditions, or at least to the vehicle's road speed.
Even a fixed tuning frequency would be functional over a range of speeds - and it wouldn't really be of much use at city speeds where acceleration/braking make up a greater share of a vehicle's fuel consumption - nor would it be of much use at speeds far greater than a combined highway cruise speed plus whatever headwind speed we might expect to encounter. A specific unit tuned for its host vehicle at 65mph road speed with 0 airspeed would still be within its effective tuning range against a 10mph head wind, or following a 10mph tailwind... and so forth.
I also have no idea how much benefit, overall, could be expected from this. I know that a correctly tuned helmholtz resonator attached to the bell of an acoustic horn can
partially mimic the effect of a longer horn, with a larger bell - and intuition tells me that the application of this to aerodynamics would mean mimicing the effect of a longer boat-tail with a smaller wake area -
but this would be extremely application and condition specific. There would be very little likelihood of a one-size-fits-all product. If anything, this idea would be best integrated into a vehicle from the factory - using structural cavities inherent to the vehicle's construction as the resonant chambers, and locating the vents where they will operate to greatest effect. The whole idea may also be completely idiotic and not offer any benefit whatsoever
I will spend a little more time refining this idea in my mind, and of course absorbing any discussion that takes place here.
I think that a practical test could be made by anyone with a van/SUV, a hitch-mounted cargo rack, and enough spare lumber and junk to build a crude box with a means of port tuning (making the port in the form of an external trombone slide, from PVC pipe, might be a good start) - then measuring the resonant wavelength of their wake with the big bulky box in place. Once you had an idea of the frequenc(ies) at which your wake resonates, tuning to meet that is academic. A large challenge here would be in keeping vent sizes and lengths manageable - we're likely dealing with some very long waves and to attack them head-on means a lot of air moving a long distance very quickly through a port. The math might tell you to make a port with 4 square inches of cross section, 45 feet long - but in addition to the obvious problem of packaging that much port, you're also asking the air in that port to travel back and forth at mach 0.5 and come out cleanly at either end - a very quick way of giving your project asthma and keeping it from working at all. Instead, a fractal approach may be called-for with either multiple chambers/vents or with taller harmonics of the offending frequency.
I haven't the time or money to fool with this at the moment, but it'd be a fun experiment to toy with and if it fails as an aero concept I'd have a cargo trunk instead
So, maybe later in the year.
