With a cubic foot capacity needing statement, plus needing to know how "hard" is the 6'6" interior height requirement (a standard enclosed cargo trailer spec), the best candidate from among production trailers might be chosen.
As I wrote (I believe on this forum) once before:
"Were I in a position to spec a cargo trailer I would do my best to keep height and width to a minimum, about 6'H and 6'W for purposes of fuel economy. It wouldn't be higher than my truck and certainly not wider. I would rather have an extra ten feet in length (well, five feet plus) than another one foot in heighth or width. An 8'H x 8'W x 20'L trailer could be 6'H x 7'W x 30'L if cubic capacity had to be identical. (Which I doubt). Here are the words of an expert:
Andrew Thomson, Can Am RV
". . weight is highly overrated as a factor when towing. Aerodynamic drag, balance and suspension are all far more important than weight. I would rather tow a trailer that is 6 feet longer and 2000 lbs. heavier than one-foot taller."
The difference between the two trailers above is 64 sq/ft frontal area versus 42 sq/ft frontal area; a reduction of one-third (conventional-hitch trailer).
All corners and edges should be greatly radiused. My nine-and-half-foot tall 34' travel trailer had such, and wind just rolled off of it, instead of piling up against -- and pushing against -- the trailer walls.
I haven't found the source, but have seen quoted numerous times that a square box versus a rounded/aero trailer had road horsepower differences for the same speed of 50HP and 30HP respectively. AIRSTREAM maintains that their trailers take 20% less fuel to tow, all other things the same. Obviously, an enclosed undercarriage."
Radius edges may not be possible (short of affixing a Don-Bur style roof DIY).
I am most impressed by
ALUM LINE trailers, specifically
GNA-8B, photo #25 of 27 in GN "Enclosed Automotive" cargo trailers as per the earlier discussion and drawings above. These aluminum trailers appear to be of the highest quality with a long list of options (and, likely a price to match).
I believe some extra length may be worthwhile, as:
With 3k miles per week postulated the possible addition of living quarters could save what one Truck LTL forum estimates is $16k annually on motel expenses. Some customization and reasonable living quarters could be a real money saver on (the killer of) road expenses. A "wet bath" with composting toilet and small grey water tank plus fresh water tank, small stove and fridge (all electric I'm thinking) plus a bunkbed and
LG Split HVAC system. A generator could be mounted on the truck in a toolbox that also houses an additional fuel tank. (And, while it isn't "aero" an attached roll-up awning would be good for those long weekends at truckstops. And the ubiquitous trucker charcoal grill.) Plus a good WiFi antenna system for the Kindle, movie downloads, etc.
Load balance may require that some freight occasionally ride in the living quarters, so adequate floor space and e-track should be provided.
If a GN is the suitable choice, then an aero rear could be added that would not be troublesome come loading/unloading I believe (and had I the DIY fab skills to make that a worthwhile statement). A
TrailerTail is said to be worth 6.6% on one aftermarket company's site. (And a Euro university said 7.5%.)
I've found at least a half-dozen other owners of Airstream type trailers such as my own where, (all 2nd & 3rd Gen) DODGE Cummins engined trucks were achieving 13-16 mpg on 28' to 34' TT's weighing from 7k to 11k at speeds reported from 55 to nearly 65 mph. I saw 13-15 in my barely less aero
Silver Streak at 63-mph (backroads vs. Interstate).
A GM
DuraDud ought to be able to inch it's way near there. (Ha!)
