Old 06-12-2012, 12:34 PM   #21 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Old Mechanic View Post
I get the same mileage at 55 on a deserted US Route 60 as I do at 65-70 on the packed I64
As SentraSE-R said :
You can't fight the laws of physics.
There's more drag at 65-70 than at 55 - be it aero, rolling, or mechanical. No way around that.
The question is how the car copes with that.
Old Mech's Fiesta will be in the same gear at either speed - so it can only be a matter of gearing and engine efficiency at the corresponding rpm.
Both are choices that Ford made when bringing it to the market, and since they don't cater for hypermilers, the Fiesta is likely geared to be at its optimum rpm somewhere around those higher, more normal speeds.
Lower rpm is only OK if the engine can still pull it off OK.
It's not always or necessarily better - though you always win a bit by not having to accelerate the extra 10-15 mph.
Originally Posted by basjoos View Post
But you can modify them with effective aeromods to flatten out that drop in mpg with increasing speed
Sure you can mod the hell out of a vehicle and reduce its drag, but it's still there - and increasing with speed.
From the speed / MPG numbers you've posted before, I recall that if you drive slower, you also get (even) better MPG.
Old 06-12-2012, 12:43 PM   #22 (permalink)
euromodder's Avatar
Originally Posted by skyking View Post
It does go back quite a ways, that beneficial effect. I wonder if a technically savvy guy could make a Cruise control input coupled with a laser rangefinder.
Maybe some indicator lights.
Two dots or thin vertical lines on the windshield could help one to keep the ideal distance - dambuster style - though not automatically.
The width of semis is a known constant.
Old 06-12-2012, 04:04 PM   #23 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Put on your drafting glasses!
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 06-14-2012, 02:08 PM   #24 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
No, get a drafting hood ornament:
Don't worry about any aero penalty, the semi will handle that.
Transmission type Efficiency
