Old 05-15-2011, 12:07 PM   #11 (permalink)
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Honda Accord EX
HvyDrnkr - '93 Cadillac Seville
How about, let's say for a front drive auto, make an electrically driven rear axle, battery pack and controller. Integrate generator into ICE at front that will cycle on and off as needed to keep batteries topped off ( ala Volt ), and drive the car primarily on electricity.
If problems arise with the electric side, use existing drivetrain as limp home or for long distances, electric side for running around town.
As a third level of redundancy, the big hp / torque starter motor, just in case.
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
Old 05-15-2011, 12:24 PM   #12 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
The idea I have in mind is more of a mild hybrid, basically intended to allow things like FAS to become more natural, and less operator based. Many feel that keying off takes too much attention from driving, and can become dangerous. I don't necessarily disagree.
Its said that the best way to get high FE from a hybrid is to simply not use the hybrid part. The 100+ mpg pulse and glide run in a Prius comes to mind. Its really inefficient to use an alternator or even a genny to charge the battery pack when that power could be used for motion. Too many energy conversions, which is why plug in fuel/electric cars are the only real hybrids in my mind.
Locomotives use electric drive with giant fuel generators for a few reasons, one being that the generators ONLY run at their most efficient load, eliminating a good bit of the problem with fuel engines right from the start. Similar tech could be applied to a car, but again, better efficiency would be had by building a more efficient CVT and allowing the fuel engine to drive the car at its most efficient load all the time. Another reason that locomotives use the hybrid power arrangement is that of power delivery... It takes ALOT of power to get a train moving, and the components needed to deliver that power safely can get very large and heavy, and at power levels in access of 10,000hp in some cases, power delivery parts tend to be a bit unreliable.
Old 05-15-2011, 01:03 PM   #13 (permalink)
What do you think about a dieselized Mother Earth hybrid? I think it falls closer to what a train does.
Old 05-15-2011, 01:17 PM   #14 (permalink)
I mentioned the power requirements for a train because of that...
Alot of people think it would be more efficient to convert the power from an engine through a generator to run an electric motor, as long as it were done at the engine's peak efficiency.
The problem with this, is that when it was designed for locomotives, the design HAD TO compensate for power requirements, as well as efficiency (as a close second, unfortunately).
This means that, for our purposes, there really is no reason to take power from an engine (50% efficiency at best), to power a generator (70%?) to power a car via electric motor/batt/
capacitor bank (heat losses, transmission losses, weight and complexity) when the same power could
be used to propel the vehicle, even via a CVT at 80% efficiency, and still have better end efficiency at the wheels.
Unless a hybrid system is used to specifically address the inefficiencies of the current system, such as idling, low load operation, etc... it's only added, weight, complexity, maintenance charges, trouble, and indeed, pollution, IMO. I've yet to see much in the line of fact to sway that opinion, in truth.
Old 05-15-2011, 02:05 PM   #15 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
There is a guy who put a 3 cylinder diesel engine from a VW lupo in a Honda Insight mated to the hybrid's motor.
Thing is, Diesel engines tend to cost a bit more because of how much more stress diesels are under and add to that the cost of a hybrid and you end up with a really expensive vehicle.
Old 05-15-2011, 02:11 PM   #16 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by jamesqf View Post
But CO2 output = mpg, no?
At least officially.
In the real world, you won't get near the official EU rating all that easily - compare them to the old EPA rating.
Consumer organisations tested the vehicles that can get a 15% Gov't discount, none of them achieved their rating in normal driving, i.e. how most people drive.
It takes some serious hypermiling to get at and go beyond the official numers
Old 05-15-2011, 05:14 PM   #17 (permalink)
Easter McoModder
SwamiSalami's Avatar
'99 Subaru OLL 2.5L - '99 Subaru Outback Legacy Limited
90 day: 22.57 mpg (US)
Rabbit - '08 VW Rabbit S
90 day: 32.93 mpg (US)
Where can I find this?
This is basically what I'm talking about.
This is really the only way to get it done, because the auto manufacturers don't get it. It's like they realize that if they come out with the ultimate vehicle today, there won't be anything for their market to look forward to.
Old 05-15-2011, 06:17 PM   #18 (permalink)
You just want me to work today, don'tya?
Here ya go,
Red Light Racing builds the worlds first Diesel Insight - MIMA Honda Insight Modified Integrated Motor Assist
The Following User Says Thank You to cleanspeed1 For This Useful Post:
SwamiSalami (05-15-2011)
Old 05-15-2011, 06:26 PM   #19 (permalink)
Easter McoModder
You rock.
Old 05-15-2011, 06:31 PM   #20 (permalink)
You rock.
If we ever meet at an event you owe me a Jamba Juice!
diesel hybrid, hybrid tdi, tdi
