Old 11-25-2010, 09:39 PM   #1 (permalink)
Increasing F-350 efficiency
I'm driving my Dad's 2002 F350, (quad cab, duallie, 4wd, automatic). Till my Mom gets out of her wheelchair he's traded me for my minivan.
The truck gets 9mpg according to the onboard computer, 11ish on the highway. With fuel economy that low even a small 2-3% increase would pay off pretty fast.
Do the typical air intake, exhaust, programmer mods actually improve fuel economy if you keep your foot out of it? Wondering what works and what doesn't?
While I realize this is hardly the typical ecomodder vehicle, I'm hoping someone here has been down this road. Over on the diesel truck forums guys are primarily interested in maximum power, regardless of fuel economy.
Old 11-25-2010, 10:26 PM   #2 (permalink)
comptiger5000's Avatar
RaceJeep - '98 Jeep Grand Cherokee (ZJ) 5.9 Limited
90 day: 13.62 mpg (US)
Is it gas or diesel? If it's diesel, it should be getting significantly better mpg than that.
Regardless, improvements in driving technique are going to yield the biggest gains short of significant modifications, and are the easiest things to do.
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Old 11-26-2010, 10:49 AM   #3 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Check the tires for uneven wear as a first step in seeing if it has proper alignment as it's common with work trucks to torque the frame while towing or using a snow plow.
It's also most likely about time for a fluid change, synthetics all around, check into getting a shop manual for it and read their list of mantainace suggestions.
Thing is, your truck is in the class of commercial duty or heavy duty trucks and does not have any EPA numbers because of that, there for it's not regulated and the mileage you are getting is most likely close to what it was designed to get.
Old 11-26-2010, 10:49 AM   #4 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 144.39 mpg (US)
Send a message via MSN to jakobnev
Lazy truckbed aeromod.
Maybe you could try something like this. The idea is to allow smoother flow in the trapped vortex, and still be discrete and simple and practical and all that.
The blue lines in the image are just bent plastic rectangles.
Old 11-26-2010, 11:04 AM   #5 (permalink)
Or he could try what's been proven- a 1/2 tonneau or a full one.
Or better yet park the dang thing and get something realistic to drive.
Old 11-26-2010, 12:42 PM   #6 (permalink)
If it's a diesel a hotter thermostat should help.
A larger less restrictive exhaust won't help MPG.
Old 11-26-2010, 01:09 PM   #7 (permalink)
Eco-ventor
jakobnev's Avatar
House of Tudor
Team Mazda
Plug-in Hybrids
True, but that's not nearly as interesting
(Do full tonneaus even work for mileage? I remember reading that they don't)
Old 11-26-2010, 01:57 PM   #8 (permalink)
Sounds like you need to study up on it then.
Old 11-26-2010, 02:02 PM   #9 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
with the aerodynamics of a barn and how heavy that thing is driver modification will yield some pretty big improvements.
Slowing down such that you don't have to use the brakes much except to stop where required will be huge.
Reducing your aerodynamic loads by reducing velocity will help a lot as well. can you go 55 in stead of 65?
depending on how long your going to be driving the f350 a cheep econ-o-box in the 500 dollar range may save some cash then sell the thing after you get your van back. please don't misunderstand as I realize a full size and very capable truck has it's place.
The performance mods, while they claim to increase mileage really don't do much, it requires a certain amount of energy to accelerate a mass and overcome the drag. performance mods can't change or reduce those energy requirements. They really only help at high power settings and that is not where economy is going to be made.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 11-26-2010, 06:10 PM   #10 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Make a tonneau cover, a partial grille block, and a front air dam that shields your undercarriage. Raise your tire pressure to 5 psig above what Ford recommends, or to the rated pressure listed on the sidewall of your tires (whichever is lower).
diesel, powerstroke
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Announcing a complete solution to mapping engine efficiency kubark42 Instrumentation 80 01-14-2011 09:36 PM
The Easy Leg: Vehicle Efficiency natefish Off-Topic Tech 17 05-19-2010 04:52 PM
Import Tuner Magazine: mods an Integra for speed, handling and efficiency MetroMPG EcoModding Central 15 03-18-2010 02:14 AM
Getting more efficiency out of a ZX2. Small list of mods and driving tips for it. koihoshi EcoModding Central 9 07-20-2008 04:26 AM
