Old 10-29-2010, 09:15 AM   #11 (permalink)
Originally Posted by mwebb View Post
camber changes on single link suspensions
( macphearson strut )
and remains relatively constant on multi link suspensions ....
either way -
a consistent
3 degrees of negative camber is going to change the loading on the wheel bearing
there will be wheel bearing failure problems as a direct result.
imho
On strut it doesn't change to much as angle is fixed ,it does go a little more negative with full depression becuase the link points gets shorter .
wishbone/multilink depends on the length of the arms/links , If you notice many newer multi link FWD suspensions if a lot of weight is on rears or car is lowered it goes way negative . It is how the manufacture sets up the suspension, they can get it to stay pretty much same angle throughout its motion .
Either way I don't see this working for the masses .
Old 10-29-2010, 09:34 AM   #12 (permalink)
93 Metro Streamliner
AeroMetro - '93 Geo Metro
You are thinking in the reference plane of the vehicle. In the reference plane of the road, the whole vehicle tilts outward, including the tires.
But with modern stiff springs, the vehicle doesn't really tilt that much.
Old 10-29-2010, 12:01 PM   #13 (permalink)
Yes, I probably should not of made such general statement .
What I really was trying to convey is vast array of suspension designs and many now don't even have adjustable camber (without some kind of 3rd party adjuster (balljoint/arms)}
Hyperinflating tires CapriRacer Hypermiling / EcoDriver's Ed 276 03-14-2022 03:51 AM
Fuel Economy related papers tasdrouille General Efficiency Discussion 41 03-19-2021 06:31 PM
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 29 09-06-2018 03:09 PM
Hydrogen Generator Experiment willy57 DIY / How-to 601 08-23-2016 05:53 AM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
