Old 03-28-2014, 11:02 PM   #11 (permalink)
05 Mustang v6 - '05 ford mustang base
90 day: 22.75 mpg (US)
Compared to my parent's RX350 which is really good at shifting their older 4Runner with a 4-spd is sluggish at slow speeds trying to shift. It just sounds terrible when it soudns like it's trying so hard to get into 2nd or 3rd I wish it wold just shift sooner.
Old 03-28-2014, 11:52 PM   #12 (permalink)
Fewer gears + better ratios FTW.
Old 03-29-2014, 01:41 AM   #13 (permalink)
...beats walking...
"2-speed slush-boxes" and "3-on-the-tree" for the nostalgia (FTN)!
The Following 2 Users Say Thank You to gone-ot For This Useful Post:
Cobb (03-29-2014), theicecreamman (04-12-2014)
Old 03-29-2014, 02:23 AM   #14 (permalink)
No- fewer gear meshes for lower transmission friction losses.
Fat Charlie (04-03-2014)
Old 03-29-2014, 02:33 AM   #15 (permalink)
Dynaflush/PowerGlides be damned!
Old 03-29-2014, 06:28 AM   #16 (permalink)
Joggernot's Avatar
Drove Chevy 2 speed autos for years. Of course gas was about $.25 back then...
The Following User Says Thank You to Joggernot For This Useful Post:
Mista Bone (03-30-2014)
Old 03-29-2014, 06:57 AM   #17 (permalink)
OK, Powerglides were not what I had in mind.
Old 03-29-2014, 09:01 AM   #18 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
A two speed Lenco then?
The Following User Says Thank You to nemo For This Useful Post:
CFECO (03-29-2014)
Old 03-29-2014, 10:02 AM   #19 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Originally Posted by Thenorm View Post
reading a review about the new Cherokee with teh 9 speed. they said they never saw it engage 9th and that it doesnt even come into play on the EPA cycle (has to be down hill, low throttle above 70mph or something rediculous)
so maybe we've hit the limit of # of gears?
Sounds like aero mods would REALLY help it out. Lower drag and a higher gear.
Old 03-29-2014, 04:34 PM   #20 (permalink)
90 day: 29.78 mpg (US)
You can trick the transmission into shifting earlier, and thereby reduce the high revving by momentarily backing off of the throttle.
I've found the minimum speeds at which the Camry will cruise in a tall gear, and when I approach these speeds, I cut the throttle to about half and the car upshifts. This all takes about 1 second, and then I get right back on the throttle to continue accelerating at about 85% load.
The '98 Camry I'm driving seems to have 4 gears with a lockup TC at the top end. It's far and away more efficient at cruising than the 6-speed manual on my Acura. The Toyota does 2000 RPM at 55mph compared to the Acura's 2400 RPM.
More gears isn't necessarily better, and there are diminishing returns on each additional gear. The goal is to keep the car in the ideal RPM range for producing peak torque while accelerating, with a sufficiently tall top gear for cruising at high speed.
The eCVT does appear to be the superior transmission, but even that has some limitations in regards to efficiency when it comes to protecting the MG (motor/generator) unit from over-revving. These limitations cause the plug in Prius to have a top electric-only speed of 62 MPH.
Cobb (03-29-2014)
