Old 02-11-2023, 05:11 AM   #11 (permalink)
LUCID's lead designer, Derek Jenkins is claiming that their upcoming 'Gravity SUV' will be the 'most aerodynamic SUV ever,' and their 'flow extender' will be 'massive.'
So I think your instincts are A-Okay.
And 'size matters.'
Interesting, thanks for the FYI.
Lucid Gravity previewed as the 'most aerodynamic SUV ever'
https://www.autoblog.com/2022/11/15/...ravity-teaser/
ademonrower, nice work.
More photos would be welcomed, the leading edge in particular is of interest, and how it's all secured - the details.
Name:	Lucid Gravid Rear Spoiler.jpg
Old 02-12-2023, 05:24 AM   #12 (permalink)
Ademonrower
Partial kammback Volvo 245 attachment method
I must apologize for not being able to find the message that requested more details on how my improvized flow-extender for the tailgate of my Volvo 245 is attached. Here are two pictures that should help. Cheers
ID:	33414   Click image for larger version
The Following User Says Thank You to ademonrower For This Useful Post:
aerohead (02-13-2023)
Old 02-12-2023, 07:51 AM   #13 (permalink)
Double sided tape, maybe a great idea, maybe a really bad idea - time will tell.
Thank you for the additional information.
ademonrower (02-14-2023)
Old 02-14-2023, 02:37 AM   #14 (permalink)
Ademonrower
Yes, I agree with you: I'm not "convinced" of the double-sided tape either, but if it is the thick kind with foam or flexible polymer between the two sticky layers, it could make a firm enough bond. I'd like other ideas on the affixment question, because it's a very important one, so please - anyone - feel free to advise me. Thanks!
Old 02-14-2023, 12:55 PM   #15 (permalink)
Super [ethyl 2-cyanoacrylate] glue? Deadheres with rubbing alchohol.
ademonrower (02-15-2023), aerohead (02-16-2023)
Old 02-16-2023, 10:00 AM   #16 (permalink)
'affixing the wing'
* the flow extender will not be exposed to significant aerodynamic loads, and some tape systems adhere so strongly that, you might destroy the device whenever you attempt to remove it.
* a lanyard, like Chrysler Corp. used on their 1969 Dodge Charger Daytona Coupe rear wing, to ensure it wouldn't strike another race car should it be knocked loose in a race, might be enough 'insurance' for your device.
* other than some structure which is captured within, and held steady in the gap of the rear hatch, from which the 'wing' could be attached to, I don't know of many options for sturdy attachment that wouldn't damage the Volvo's paint.
* I don't think you want to drill holes in body parts, and then run fasteners 'out' through the hole, into a female threaded insert, bonded to the 'underside' of the 'wing,' with a weather-proof gasket, like carmakers do.
ademonrower (02-17-2023)
Old 02-17-2023, 04:42 AM   #17 (permalink)
Ademonrower
Very good ideas and advice: indeed, NO to drilling holes: bad thing for a classic car, but your message made me think, perhaps I can make a clip-on fastner to the vertical rim of the tailgate: that would, at least, give the extender a holdfast at the side as well as on the roof-level rim of the tailgate... Will experiment and post pics...
aerohead (02-20-2023)
Old 03-10-2023, 04:16 PM   #18 (permalink)
AdrianD's Avatar
Here's some inspiration from another guy with a boxy station wagon:
https://ecomodder.com/forum/showthre...mph-13476.html
I'm following to see the results since I want to add a similar spoiler to my SUV
kammback, tailgate spoiler, tailgate wing, volvo 245
