Old 12-28-2012, 09:27 PM   #1 (permalink)
Iam not green just cheap.
1998 ex honda civic black - '98 Honda Civic ex
90 day: 37.82 mpg (US)
less air intake
would less air going into the air intake help on mpg?
Old 12-28-2012, 09:46 PM   #2 (permalink)
ron
double eagles - '99 Dodge ram slt
90 day: 19.48 mpg (US)
your engine is a positive displacement pump the slower it turns the better your fuel consumption should be, so I would say yes.
The Following User Says Thank You to ron For This Useful Post:
Daniel8171986 (12-28-2012)
Old 12-28-2012, 09:50 PM   #3 (permalink)
RobertISaar's Avatar
MC SBX - '95 Chevrolet Monte Carlo LS
Last 3: 29.75 mpg (US)
couple of things to consider:
how is your ECM measuring airflow? MAF or speed-density?
if you alter the VE via intake changes so that less air is entering the engine for a given RPM and manifold pressure, the MAF system will adapt, since it only measures airmass, but a speed-density engine would actually run richer due to the ECM thinking more air is entering the engine than reality. the O2 sensor will allow for it to adapt eventually, but until then, you'll actually lose fuel efficiency.
The Following User Says Thank You to RobertISaar For This Useful Post:
Old 12-28-2012, 10:15 PM   #4 (permalink)
what if its a honda d16y8. they use a map sensor?
Old 12-28-2012, 10:56 PM   #5 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
Seems like the same affect as using less throttle, how would this be different?
The Following User Says Thank You to 2000mc For This Useful Post:
Old 12-28-2012, 11:06 PM   #6 (permalink)
okay thanks. ill try and see what happends.
Old 12-29-2012, 12:56 AM   #7 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
A quick Ecomodder search:
http://ecomodder.com/forum/showthrea...est-19054.html
Old 12-29-2012, 03:46 AM   #8 (permalink)
vskid3's Avatar
Civic DX (sold) - '97 Honda Civic DX
90 day: 34.15 mpg (US)
GTO (sold) - '04 Pontiac GTO
90 day: 22.62 mpg (US)
Green Brick (sold) - '06 Ford Escape Hybrid
90 day: 31.93 mpg (US)
Originally Posted by mechman600 View Post
Frank sums it up quite well in that thread:
My gut tells me to feed it.
But it always says that. If I listen closer it also tells me that the throttle plate takes care of ALL the engine's intake restriction needs... and it's fully adjustable too!
Less air going in the engine will help, but you can do that with the throttle.
Camry Thread
E-Bike Thread
The Following User Says Thank You to vskid3 For This Useful Post:
Daniel8171986 (12-29-2012)
Old 12-29-2012, 04:10 AM   #9 (permalink)
Jenny - '02 Chevrolet Prizm Lsi
90 day: 27.55 mpg (US)
Crowley - '23 Ford Maverick XLT
90 day: 30.43 mpg (US)
That seems completely logical to me. Wonder if it would be worth running a larger intake to lean the mix out a little?
Old 12-29-2012, 04:15 AM   #10 (permalink)
keep in mind, i'm referring to being able to effectively change the volumetric efficiency of the engine.... changing anything upstream of the throttle usually won't qualify/have enough of an effect. sure, you could (for example) suck hotter air and have the air be less dense, but air temp is also factored into both speed-density and MAF.
