Old 12-12-2014, 03:42 PM   #11 (permalink)
betasniper's Avatar
Red - '01 Honda Insight CVT
Gen-1 Insights
House of Tudor
90 day: 59.17 mpg (US)
Civic Hybrid - '12 Honda Civic Hybrid
Bahamut - '18 Chevrolet Volt LT
Team Volt
Plug-in Hybrids
The rotor is the valves and the combustion chamber all in one. It is a 4 stroke engine, but there are three combustion events per revolution of the rotor.
Technically true, But the output shaft rotates at twice the speed of the rotor so it is actually still equivalent to a 3 cylinder engine. (3 combustion events every 2 revolutions). Still a nice idea. Could be great as a 2 rotor(6 cyl equivalent) for a regular car.
: Brothers
: Dad's
Old 12-12-2014, 03:59 PM   #12 (permalink)
Bullets and pistons are round for a reason. Highest volume for surface area, mating surfaces expanding and contracting at the same rate. Easy to seal and long lasting.
Now get rid of the reciprocation costs, valve train costs and minimize the heat losses to the cylinder head and manifolds by using the exhaust to preheat the intake, combined with a single injector and inlet port for combustion events and you're speaking my language.
regards
mech
Old 12-12-2014, 04:29 PM   #13 (permalink)
betasniper's Avatar
Gen-1 Insights
House of Tudor
Team Volt
Plug-in Hybrids
A Theoretically Ideal engine would likely be a expandable spherical chamber but I am not sure how that would work. Circles are easier to seal with a back up compression ring, but this engine doesn't seem to have the traditional problems of a wankel seal because the sides of the apex seal can butt up against the side walls of the housing.
Old Mechanic: Could you tell me which frame (or second) in the 14sec video you see the pressure opposing rotation? I'm pretty sure regular piston engines also ignite the mixture before TDC by about 30° of crank rotation which also tries to oppose the crank.
: Brothers
: Dad's
Old 12-12-2014, 05:28 PM   #14 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 144.39 mpg (US)
Send a message via MSN to jakobnev
It's a bit ironic perhaps, but things that work tend to be invented once, things that don't however..
Old 12-12-2014, 05:46 PM   #15 (permalink)
IamIan's Avatar
They have tested it at 3HP on the dynamometer For a 70cc engine.
FYI ... AFAIK this is just the most recent 'version' prototype ... sense the company founded back around ~2004 ... They have had other prototypes of earlier versions... As I recall , there is a SAE paper from ~2010 on a 20HP 140cc prototype ( the "M2" )
Link
Previously, LiquidPiston has demonstrated proof-of-principle 70 and 40 HP engine prototypes (X1 and X2) that are capable of running for a short time at light load, and demonstrate compression ignition of diesel or JP-8 fuel, and net indicated efficiency of 33% (at light-load)
I'm wishing them the best for more improvements in the future.
Life Long Energy Efficiency Enthusiast
2000 Honda Insight - LiFePO4 PHEV - Solar
2020 Inmotion V11 PEV ~30miles/kwh
Old 12-13-2014, 12:32 AM   #16 (permalink)
So, it lacks all the parasitic losses of a reciprocating engine with poppet valves, but it may be harder to seal.
We will have to see how they proceed from here.
Old 01-01-2017, 08:27 PM   #17 (permalink)
I wouldn't really hold my breath for a rotary engine, but it could become a reasonable option for the general aviation if it can overcome the durability issues that have always plagued the Wankel design.
Old 01-02-2017, 05:42 AM   #18 (permalink)
Volvo-driving MachYeen
Fingie's Avatar
Neo Volvo - '98 Volvo S70 10V
90 day: 24.98 mpg (US)
isn't rotary pretty reliable in constant-rpm applications?
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
Old 01-02-2017, 10:47 AM   #19 (permalink)
The big difference with this and the Mazda one is the piston does not rotate it oscillates so much simpler to seal
Black Lupo 3L 1.2tdi Manual converted the windsurfing bus!
Kermit the Lupo 3L 1.2 Tdi with a current mpg record of 114mpg (imperial) Now sold
G1 JDM Insight I hate the ride but love the quirkiness
Old 01-02-2017, 08:16 PM   #20 (permalink)
Had them been reliable at all, don't you believe they would have taken over the stationary/industrial market already?
