Old 04-16-2012, 01:37 AM   #11 (permalink)
MALIBU MOD - '07 chevy malibu 2LT
90 day: 29.39 mpg (US)
average avao - '09 chevy avao LT
90 day: 32.68 mpg (US)
Ok thank you, I will probably try and find some calking as well to hold it in place. I will try and remember to post some pics. You have all been very helpful
GO BLUE!
Whether you think you can or you can't, your right.
-Henry Ford
Old 07-12-2012, 01:21 AM   #12 (permalink)
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
GO BLUE!
How did this end up turning out?
I am eager to work on this, but would like to see more work first. Good? Bad?
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
Old 07-14-2012, 12:58 PM   #13 (permalink)
TBD - '17 Toyota Corolla LE
Last 3: 36.26 mpg (US)
Starship - '08 Toyota Prius
90 day: 45.24 mpg (US)
Starship Resurrected - '08 Toyota Prius
I used this from McMaster-Carr to good effect:
McMaster-Carr
Specifically catalog # 93085K81, Style 5, but there are many on the page that would do:
Old 07-14-2012, 09:56 PM   #14 (permalink)
clank - '99 jeep tj sport
90 day: 17.32 mpg (US)
my personal favorite is open cell weather stripping($11/25' roll), only major problem is freezing water, and a little bit of sticking; and comes in most major sizes(3/4" is on my hood, 1/4" is around the grill inserts,3/8" is in the grill)
Old 01-05-2015, 06:12 PM   #15 (permalink)
90 day: 55.4 mpg (US)
I filled the gaps between the doors and other body panels and the gap between the roof and the boot window.
I used 3M black sealing foam tape.
Here's the boot window gap (it still remains partly open, but will make a difference):
The tape is wider than the ridge at the doors.
I could have cut it narrow (it is easy to cut with scissors) but decided to just press it in the fold for added insulation., like here below the B pillar:
When closed you only see the side of the tape, flush with the panels:
After a few days the tape gets loose in some spots.
I prepped the underground with white gas (petroleum ether) and it did stick very well initially, but maybe the strip glue does not work well with moisture?
I may prep it with thinned glue when I get the chance.
