Old 02-17-2011, 11:44 PM   #31 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
instead of solenoids why don't you get a 6 foot choke cable? you can set up a couple pieces of small aluminum "c" channel with a piece of coroplast to slide on them, pulling on the choke cable could open the block and allow more air in, after the engine temp stabilizes you can slowly close the opening until it creeps up then leave it alone
The Following User Says Thank You to Joenavy85 For This Useful Post:
CigaR007 (02-18-2011)
Old 02-18-2011, 12:49 PM   #32 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
@ Joenavy85
Thanks for the suggestion, I will definitely look into it.
Originally Posted by alohaspirit View Post
nice!
no pics yet?
Should have some pics by tomorrow, promised !
Old 02-18-2011, 02:13 PM   #33 (permalink)
Originally Posted by CigaR007 View Post
@ Joenavy85
i was bored out of my mind at work yesterday (24 Hour Shift) and was inspired to come up with something like you were thinking of for my Jeep, and that's what i came up with. you'll likely need to make some sort of 90* arm since the choke cable is only 6' long.
Old 02-19-2011, 09:07 AM   #34 (permalink)
CigaR007's Avatar
As promised !
The Following User Says Thank You to CigaR007 For This Useful Post:
alohaspirit (02-19-2011)
Old 02-19-2011, 08:14 PM   #35 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
looks pretty good
Past Present Future?
The Following User Says Thank You to alohaspirit For This Useful Post:
CigaR007 (02-19-2011)
Old 02-19-2011, 08:33 PM   #36 (permalink)
CigaR007's Avatar
looks pretty good
Thanks ! The only drawback is that it makes it difficult to do an actual ABA testing. I would have to buy a new upper OEM-style grille and switch it.
Which reminds me, the lower grille block is in need of a makeover...
Old 02-21-2011, 12:27 AM   #37 (permalink)
Grasshopper
i would think you could just remove the entire thing for ABA testing
Old 02-21-2011, 03:41 PM   #38 (permalink)
CigaR007's Avatar
That is indeed a possibility. Although, wouldn't it artificially "inflate" the gain from the full upper grille block ? Pretty sure an opening that big would create a fair amount of drag; especially at highway speeds.
Old 02-28-2011, 10:01 PM   #39 (permalink)
Grasshopper
i think the open-grill is very similiar to no-grill
how much of an increase would you peg the upper grill block at?
Old 03-01-2011, 10:59 PM   #40 (permalink)
CigaR007's Avatar
It's hard to say really. Without an actual A-B-A testing, it remains speculative, based solely on a tank-to-tank basis. I will have a better idea once I fill my next tank. But so far, it looks promising.
Check my fuel log in the coming days. There should be a trend shaping up.
The only constant is my daily commute, which is about 60 miles, 95 % highway with an average speed of 50 mph. I average 45+ MPG in both directions every single day. The main variable would be the weather, which has been better (warmer) over the last few weeks. I had two consecutive tanks at 44 MPG and the next two are shaping up to be at 47 and 48-49 respectively.
The driving technique is always the same at key points. There is about 3 miles of Engine On Coasting in each direction for a total of about 6 miles depending on traffic density. No other specific technique, I just monitor the GPH, LOD and MPG to maintain a high efficiency.
A 1 or 2 MPG gain wouldn't be a far stretch in my opinion.
aero mod, grille block, toyota echo
