Old 02-13-2009, 04:08 PM   #11 (permalink)
Know of any solenoid valves that can flow enough coolant and aren't $100+? I searched mcmaster.com for solenoid steam valves and they are EXPENSIVE.
Old 02-13-2009, 04:14 PM   #12 (permalink)
"...and how they went to using exhaust heat to speed up the warming up of engine..."
My '66 Corvair has that feature! LOL
Old 02-16-2009, 12:15 PM   #13 (permalink)
Silver Turtle - '02 Ford Focus Zx3
90 day: 38.83 mpg (US)
And how much faster the coolant heats up? 5 seconds? not worth it... 1 minute faster? WORTH IT
Old 02-16-2009, 12:25 PM   #14 (permalink)
Perhaps I'll do a test tonight. I'll fire up the car in the garage and let it idle. I have an IR thermometer and I'll measure how fast the exhaust pipe heats up. I'm betting its pretty darn quick.
Old 02-16-2009, 12:42 PM   #15 (permalink)
Make some kind of moving heat exchanger. To heat up it moves to touch the exhaust and when hot enough, a motor removes the contact, separating it from the exhaust.
Old 02-16-2009, 12:52 PM   #16 (permalink)
That would be awesome because I am contemplating doing this MAJORLY. And not only for the coolant, but the transmission and oil liquids as well.
Let us know pleeease
Old 02-16-2009, 01:12 PM   #17 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
Thinking about it, that's what the cooled EGR on my TDI do.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 02-16-2009, 02:04 PM   #18 (permalink)
Thats pretty much what I was thinking. I have some initial rough sketches. Might as well share them. The top assembly would be soldered together, and with more tubing. It would ride up and down guided by pins or bolts or something, one on each end. The aluminum tube cut in half would help capture more heat and keep the unit smaller and cheaper. It would also allow for easy mounting with a clamp on each end.
Old 02-16-2009, 03:31 PM   #19 (permalink)
Prius does it cuz engine is on/off so much.
Gotta wonder if it warms up much faster than regular stuff from initial start up?
I mean, with thermostats and especially us with grille blocks, it's only a matter of minutes anyway. I bet coolant doesn't even get overly cool with big P&G.
I think it's a hybrid thing.
Old 02-16-2009, 03:36 PM   #20 (permalink)
Efficiency freak
Bearleener's Avatar
Frugolf - '96 VW Golf wagon
90 day: 40.36 mpg (US)
Here's a PowerPoint about a simulation of various auxiliary heating systems.
http://www.vda-wintermeeting.de/file...DA-Handout.pps
The focus was primarily on warming up the passenger compartment faster when you have an efficient diesel engine (not enough waste heat), but there are interesting comparisons on Slides 14 and 15.
Below is Slide 14. The yellow curve is exhaust heat recovery. Doesn't look too great, but on Slide 15 it has negative fuel consumption, i.e. it saves fuel.
I'm thinking an oil heater: a separate water circuit from the exhaust heat exchanger to tubing wrapped around the oil filter. A pump would circulate the water only when desired, greatly reducing additional, unwanted heat at the oil filter when the engine is warm. An overflow reservoir could accomodate the thermal expansion of the coolant-water mix.
You ever notice that birds pulse & glide, too?
The Following 2 Users Say Thank You to Bearleener For This Useful Post:
Josh8loop (02-22-2013), Piwoslaw (02-09-2011)
PBS takes the Hummer v Prius bait SVOboy Hybrids 51 05-19-2010 12:35 PM
Converting Exhaust Heat to Electricity SuperTrooper General Efficiency Discussion 13 03-20-2010 06:03 AM
Waste Heat from Exhaust TES111 EcoModding Central 35 11-21-2008 12:31 PM
Why does the heater core transfer heat from the coolant, not the exhaust? extragoode General Efficiency Discussion 23 10-17-2008 10:44 AM
Steam engine (from exhaust heat) iHero General Efficiency Discussion 23 09-08-2008 12:30 AM
