Old 06-29-2011, 11:57 AM   #81 (permalink)
Interesting--that increased the variance again, but also pulled up the mean enough that we have a p-value of .0348; or 3.5%. If we'd done the experiment under rigorous conditions and documented it thoroughly, that'd be good enough for journal publication. Well, also if we'd used a more appropriate statistical test and had a lot more data.
Given those results, I just might have to get me some airtabs.
Right now, I'm recording the mpg of every highway-only trip I take, which is a pretty decent amount since I live next to a freeway onramp. As long as traffic allows me to drive ~70mph most of the way, I record the mpg right before I decelerate for the offramp. I figure that'll help isolate the effects of drag as much as possible.
If I do buy airtabs, I will write my conclusions and methods up in a post here. I will also probably point to that post in an argument against the useless A-B-A test method that somehow rules the ecomodder forum
Old 06-29-2011, 08:54 PM   #82 (permalink)
Dr. Jekyl - '09 Mini John Cooper Works
90 day: 47.07 mpg (US)
Thanks for posting the upshot of the last set of data. It occurred to me that a tank's worth of consumption over several hundred miles of driving really represents quite a number of data points. This despite our considering only the end result distance/consumption result as a SINGLE data point.
Old 08-05-2011, 11:26 AM   #83 (permalink)
I just notice that you can't use the stock exhaust. :/
Old 08-05-2011, 11:29 AM   #84 (permalink)
Stock exhaust = heavy & restrictive
Old 08-05-2011, 11:32 AM   #85 (permalink)
aftermarket = too much moola. Was thinking of doing the One Ball Exhaust Mod, wonder if there is any other gains besides better exhaust note.
Old 08-05-2011, 11:35 AM   #86 (permalink)
1 ball is also lighter, but yeah, the exhaust note will change, some say it's too raspy...it will be louder than stock for sure.
Old 08-05-2011, 11:36 AM   #87 (permalink)
Easy to do on my own? or better for a shop to do it? something to play around with until I save enough money for a Miltek
Old 08-05-2011, 11:42 AM   #88 (permalink)
Unless your a skilled welder, I would have a shop do it.
If you haven't already, check this out:
Do It Yourself DIY One-Ball Exhaust
Old 10-16-2011, 12:22 AM   #89 (permalink)
Ladogaboy - '11 Mitsubishi Lancer EVO GSR
Team Emperor
90 day: 27.64 mpg (US)
E85 EVO - '11 Mitsubishi Lancer EVO GSR
90 day: 21.38 mpg (US)
Nice job! I'm curious about how this diffuser is holding up. My main concern is the heat from the exhaust melting the diffuser.
My car has a stock rear diffuser, but I think I might try extending the paneling underneath.
Old 10-16-2011, 03:05 PM   #90 (permalink)
After almost a year on the car its holding up very well. No problems with heat, since the top side is covered with an application of aluminum duct tape.
2004 MINI Cooper S - Improving Aerodynamics iplaysdrums Aerodynamics 90 08-08-2012 02:13 AM
Drag Racing Aero Help Bennett_Racing Aerodynamics 33 06-28-2010 06:02 AM
rear diffuser fabrio. Aerodynamics 30 05-17-2010 12:36 AM
rear diffuser build thread LeanBurninating Aerodynamics 24 06-06-2009 08:32 PM
