08-03-2014, 12:34 PM
#62 (permalink)
What brake pedal?
Use a GPS if you have one or can borrow one to calibrate the odometer/speedometer.
The Following User Says Thank You to digital rules For This Useful Post:
08-03-2014, 12:41 PM
#63 (permalink)
Woody - '90 Mercury Grand Marquis Wagon LS Last 3: 19.57 mpg (US) Brick - '99 Chevrolet K2500 Suburban LS Last 3: 12.94 mpg (US) M. C. - '01 Chevrolet Impala Base 90 day: 18.73 mpg (US) R. J. - '05 Ford Explorer 4wd 90 day: 16.66 mpg (US)
Now I have another reason to buy one. Thanks for that.
08-03-2014, 12:58 PM
#64 (permalink)
What brake pedal?
You can also use mile markers along the highway, but would need at least 100 miles to dial in an accurate number.
08-03-2014, 10:37 PM
#65 (permalink)
Thanks. I have access to a highway and to the time, It's just a matter of doing it.
08-29-2014, 05:22 PM
#66 (permalink)
OK, Fill-up day.
Not much to say about the mods - I pumped the tires to 45 Hot now. But now I need to find what the actual mileage is VS odometer. I multiplied the 408 miles by 1.15 (To go in-between 1.09 and 1.2) which got 468.6 Miles and between 21 and 22 MPG on this last fill-up. That's in the neighborhood of 35 PSI in the tires for the whole tank.
I will say the car coasts a lot more now, at 45 PSI Hot.
I'm still thinking of changing the fan. And what else is, the fan in the Mercury we got is constant too, not on-demand so that may be changed some time.
08-30-2014, 01:36 AM
#67 (permalink)
So, replace the fans on both. It's a fairly cheap mod and in some circumstances can increase efficiency from 3 to 5%.
08-30-2014, 10:17 PM
#68 (permalink)
I understand it reduces warm-up time.
08-30-2014, 10:22 PM
#69 (permalink)
It does. And actually it also helps regarding efficiency improvements, since the engine would be wasting less fuel to get into the optimum operational temperature.
09-02-2014, 06:15 PM
#70 (permalink)
I went on a trip today. The odometer read that I went 104.85 (rounded off) miles, I actually went 107.1 according to Google Maps. So, Multiplying by 1.022 gets close to the actual reading.
This also means the tires didn't make much of a difference MPG wise (For just one tank) to the last ones when run at the same PSI (35) but I did bump these new ones up to 45 Hot at fill-up time, and the previous tires said "35 PSI Max."
... I need to put other mods on than just the tires if I'm going to get past 25 MPG frequently. A new fan does come to mind and I wonder if replacing the air-pollution equipment would be of benefit, if it hasn't been replaced. Surely there are some CATs that are more efficient than there were in 1983.
I do still have the Diesel Conversion in mind (With the proper engine + Manual Transmission and 20 Gallon Diesel Tank = Instant 30+ MPG HWY in my mind.) but I'm thinking of doing some other things first.
