Old 03-04-2016, 11:28 AM   #1 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
Mpguino code help
I've wired up my arduino like this and go to download the code and it comes up with error messages. I know how to code a little but not something this extensive. I decided to use the older version because the schematic was simpler and the more up to date one didn't have any functions that I really needed. I was hoping someone who already knew how the code worked could fix it for me. I really just want the instant and tank mpg, miles left in tank would be nice but I don't really need it. Thanks for any help.
Matt
Old 03-04-2016, 11:29 AM   #2 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
code http://opengauge.googlecode.com/svn/...no/mpguino.pde
Old 03-04-2016, 05:45 PM   #3 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Can you post the error messages that you're getting?
Old 03-04-2016, 10:53 PM   #4 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
Here is the copy and paste version. and again thank you.
Unrelated question: how do you get your vehicle to show up in the signature area of your posts?
Matt
Arduino: 1.6.7 (Windows 7), Board: "Arduino/Genuino Uno"
mpguino:524: error: 'prog_char' was not declared in this scope
char * getStr(prog_char * str){
mpguino:524: error: 'str' was not declared in this scope
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino:14:191: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char * parmLabels[]={"Contrast","VSS Pulses/Mile", "MicroSec/Gallon","Pulses/2 revs","Timout(microSec)","Tank Gal * 1000","Injector DelayuS","Weight (lbs)","Scratchpad(odo?)","VSS Delay ms"};
mpguino:276: error: 'prog_char' does not name a type
prog_char * displayFuncNames[displayFuncSize];
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino: In function 'void setup()':
mpguino:278: error: redefinition of 'void setup()'
void setup (void){
mpguino:1: error: 'void setup()' previously defined here
void setup() {
mpguino:282: error: 'displayFuncNames' was not declared in this scope
displayFuncNames[x++]= PSTR("Custom ");
mpguino:309: error: 'getStr' cannot be used as a function
LCD:rint(getStr(PSTR("OpenGauge ")));
mpguino:311: error: 'getStr' cannot be used as a function
LCD:rint(getStr(PSTR(" MPGuino v0.75")));
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino: In function 'void loop()':
mpguino:346: error: redefinition of 'void loop()'
void loop (void){
mpguino:6: error: 'void loop()' previously defined here
void loop() {
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino:371:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
simpletx(",");
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino:373:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
simpletx(",");
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino:375:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
simpletx(",");
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino:377:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
simpletx(",");
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino:379:18: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
simpletx("\n");
mpguino:414: error: 'getStr' cannot be used as a function
LCD:rint(getStr(PSTR("Setup ")));
mpguino:421: error: 'getStr' cannot be used as a function
LCD:rint(getStr(PSTR("Tank Reset ")));
mpguino:424: error: 'getStr' cannot be used as a function
LCD:rint(getStr(PSTR("Current Reset ")));
mpguino:430: error: 'displayFuncNames' was not declared in this scope
LCD:rint(getStr(displayFuncNames[screen]));
mpguino:430: error: 'getStr' cannot be used as a function
mpguino:434: error: 'getStr' cannot be used as a function
LCD:rint(getStr(PSTR("Brightness ")));
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino:436:23: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
LCD:rint(" ");
mpguino:439: error: 'displayFuncNames' was not declared in this scope
mpguino:439: error: 'getStr' cannot be used as a function
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino: At global scope:
mpguino:524: error: redefinition of 'char* getStr'
mpguino:524: error: 'char* getStr' previously defined here
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino: In function 'void doDisplayBigInstant()':
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino:540:62: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
void doDisplayBigInstant() {bigNum(instantmpg(),"INST","MPG ");}
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino: In function 'void doDisplayBigCurrent()':
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino:541:63: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
void doDisplayBigCurrent() {bigNum(current.mpg(),"CURR","MPG ");}
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino: In function 'void doDisplayBigTank()':
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino:542:60: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
void doDisplayBigTank() {bigNum(tank.mpg(),"TANK","MPG ");}
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino: In function 'void doDisplaySystemInfo()':
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino:547:35: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
LCD::gotoXY(0,0);LCD:rint("C%");LCD:rint(forma t(maxLoopLength*1000/(looptime/100)));LCD:rint(" T"); LCD:rint(format(tank.time()));
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino:547:106: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino:550:43: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
LCD::gotoXY(0,1);LCD:rint("FREE MEM: ");LCD:rint(format(mem));
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino: In function 'void tDisplay(void*)':
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino:563:35: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
LCD::gotoXY(0,0);LCD:rint("MH");LCD:rint(forma t(t->mph()));LCD:rint("MG");LCD:rint(format(t->mpg()));
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino:563:81: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino:564:35: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
LCD::gotoXY(0,1);LCD:rint("MI");LCD:rint(forma t(t->miles()));LCD:rint("GA");LCD:rint(format(t->gallons()));
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino:564:83: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:28:0,
from sketch\mpguino.ino.cpp:1:
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino: In function 'void LCD::init()':
mpguino:618: error: variable 'chars' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
static byte chars[] PROGMEM ={
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino: In function 'void bigNum(long unsigned int, char*, char*)':
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino:910:14: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char * r = "009.99"; //default to 999
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino:920:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
LCD:rint(" ");
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino:922:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
LCD:rint(" ");
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino:924:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
LCD:rint(" ");
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino:929:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
LCD:rint(" ");
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino:933:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
LCD:rint(" ");
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino: In function 'void editParm(byte)':
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino:1114:26: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
LCD:rint(" ");
C:\Users\Matt\Documents\Arduino\libraries\mpguino\ mpguino.ino:1120:24: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
LCD:rint(" OK XX");
exit status 1
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
Old 03-06-2016, 07:55 PM   #5 (permalink)
MPGuino Supporter
t vago's Avatar
Ah. You'll need to find an obsolete version of the IDE to compile this. I don't know where one could be found.
The Following User Says Thank You to t vago For This Useful Post:
M_a_t_t (03-07-2016)
Old 05-16-2016, 10:28 AM   #6 (permalink)
Veen's '09 FIT - '09 Honda FIT Sport
Wagons
90 day: 43.41 mpg (US)
If it's just an obsolete version you need. Generally 1.0.6 works well when 1.6.X doesn't. You can download it from the Arduino website here https://www.arduino.cc/en/Main/OldSo...eases#previous
I use Arduino and other micro-controllers a lot but have I don't have any experience with the MPGuino code base. Hopefully this helps.
Old 05-16-2016, 06:08 PM   #7 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Try not to open INO file but just copy and paste the code as a text.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 02-04-2017, 08:16 AM   #8 (permalink)
Can you find a solution?
Old 02-04-2017, 05:34 PM   #9 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Welcome Berkin
I am also interested in this, as you live close by maybe i can help you out a little bit.
Old 02-04-2017, 06:02 PM   #10 (permalink)
MPGuino Supporter
t vago's Avatar
I have a version of MPGuino that is far more capable that the original v0.86 code, it supports many different Arduino platforms, and it compiles with the current Arduino IDE.
mpguino code
