Go Back   EcoModder Forum > AltModding > Saving@Home
Old 06-06-2024, 08:21 PM   #11 (permalink)
I had to go all the way back to post #1 to find the reference.
I have my own design, of course. It has a general leveling (see the cut-and-fill that Geoships did). But then to mimic historical precedents it has a fire ring in the center, in a sunken conversation pit.
Except this fire ring would be a smokeless fire pit..
The two step pit would have a sump underneath and an air tube that spirals in from the outside. When the fire pit is not in use, it can be a fan-driven earth-tempering air intake.
Any arbitrary soil sample will need amendments, usually clay or sand. A rammed earth floor can be stabilized with ox blood or rice water. Upper floor levels would be shoes off, burnished hard wood.
Three conspiracy theorists walk into a bar --You can't say that is a coincidence.
Old 06-07-2024, 10:38 AM   #12 (permalink)
Oxblood? Ummm that's a programmer's insider joke.
The issue I see with ceramics is that they tend to be brittle and don't like movement. Not a candidate in the west. However depending on definition, bricks are ceramic and if one used a RTV you could get ceramic "bricks" to work well
Old 06-07-2024, 02:10 PM   #13 (permalink)
It was the practice in Medieval times, when oxen were more common. Can't find a reference.
Technically, it's a geopolymer. The Geoship CEO, Morgan Bierschenk, describes it as similar to bone. It cured at room temperature, in from 45 down to 3 minutes, depending on how hot the mix is.
Old 10-17-2024, 07:52 PM   #14 (permalink)
I emailed this to someone else, and thought I'd post it here.
A ten-sided plan with five partial domes surrounding a central one. The two-frequency domes provide a continuous top plate over door and window locations.
Old 11-04-2024, 05:16 PM   #15 (permalink)
Kirsten Dirksen does Geoships. There is an interesting progression -- the first half is a good look at the factory and their one built example. Then it flashes two or three minutes of computer graphic walk-throughs and fly-throughs and finishes with an extended visit to their chief designer's glamping setup.
They haven't solved the ingress/egress problem. Here's how to make an octagon house zome (not dome) with flat walls (or not):
A 15.5ft cube gives a 10ft primary edge length
