Old 04-11-2012, 03:53 PM   #11 (permalink)
After looking at some TDI swaps, I don't think I'll be going that route. It looks like a VERY difficult swap, and the mpg is comparable to the MB anyways (at least in the some of the swaps I looked at). This could be something I can research and do down the road (maybe), but for now I want something a little easier. Those Detroits are LOUD. I like the mpg they get, but it's not practical for a car that is driven daily and usually with kids. Right now I'm still looking for more gas options. I like to see what others have done. That way I won't be disappointed with mpg figures after the swap is said and done.
Old 04-12-2012, 02:47 AM   #12 (permalink)
MALIBU MOD - '07 chevy malibu 2LT
90 day: 29.39 mpg (US)
average avao - '09 chevy avao LT
90 day: 32.68 mpg (US)
GM's 3.5 v6 is a very reliable motor, I have had it in a 88 corsica, and now my 07 malibu, easy to work on and if you can find one with a Manuel trans it would ne even better on gas. You could find one cheap and should be able to squeeze some decent mpgs
Whether you think you can or you can't, your right.
-Henry Ford
Old 04-12-2012, 05:41 AM   #13 (permalink)
Ps. I know you said you don't want a bunch of weight reduction, another option is swapping old parts with newer lightweight parts, for every 100 lbs loss you can gain 1-2% efficacy. My malibu weighs 3297 lbs and I'm averaging 29 mpg with the 3.5 v6 auto. You might be able to get a rough estimate if you can figure out your chassis weight and the motor and trans weight. Of course there will be quit a bit of variation with the aerodynamic properties of your 50s Chevy.
I love your idea of old and new, and am excited to see how it turns out, no matter what you decide
-Henry Ford
Old 04-12-2012, 05:50 AM   #14 (permalink)
-Henry Ford
Old 04-12-2012, 02:47 PM   #15 (permalink)
I'll have to look into the 3.5 v6. I was liking the idea of the Atlas engines (any one of them), and they seem to have decent MPG and great power. I think with a little tuning and a 5 speed, they should do pretty well in the '50. I haven't weighed the car yet, but from the research I've done, these cars weighed about 3300 lbs. It should get a little lighter when switching from the stovebolt engine/trans/torque tube setup to a modern driveline. That and maybe an aluminum driveshaft, lighter wheels with skinny LRR tires, and an aluminum radiator. This car won't have power windows or AC or anything. I want the interior to be close to stock except maybe a recover in a more durable vinyl (tuck n roll).
Old 06-28-2012, 05:05 PM   #16 (permalink)
Golden Egg - '95 Geo Prism LSI
90 day: 32.48 mpg (US)
Family Truckster - '99 Mercury Mountaineer 4x4
90 day: 16.03 mpg (US)
Big Green Machine - '89 Chevrolet V3500 3+3 4spd 4.56diff.
90 day: 11.47 mpg (US)
Hondyssey - '04 Honda odyssey
90 day: 23.13 mpg (US)
Any progress?
I had a thread going similar to this last fall. I opted to start with the old 235 and am in the throws of installing a Nova rear-end. I picked up a couple of 50's 3spd+OD transmissions so I can keep the 3 OTT shifter. I plan my freeway rpm's to be at 2,000. This will give me flexibility in case I want a different engine/trans later on.
The GM 8.5" diff's can have 2.24, 2.56, 2.73, 3.08, 3.42, 3.73 or 4.10/4.11:1 ratios; I currently have a 2.24, 2.56 & 2.73 but I might have to jump up to a 3.42. If you have questions on how to get a later rear-end into your Chev. let me know; also jump over to CT, they know.
Old 06-28-2012, 06:12 PM   #17 (permalink)
Smooth Operator
Old Yellar - '79 MGB Tourer Drop-Hood Coupé
Sports Cars
90 day: 25.83 mpg (US)
Old Brown Ford - '91 Ford Bronco Custom
MAGNUM - '05 DODGE MAGNUM SXT
if you are building one up ya can do it anyway you wanna
build me one .
little bitty engine . lots of gears
5 speed main box and a 2 0r 3 speed axle.. an electric would be OK but id rather have a manual auxiliary.
i doubt one can find a 3 speed aux. small and light enough , but
they have some electric 2 -speed that are light weight , or used too.
it might not accelerate fast but think of the fun shifting 15 forward gears ,
keep that little power plant wound up to peak torque with WOT and row your way to the next stoplight with the gear lever
Old 06-28-2012, 07:33 PM   #18 (permalink)
I would use the GM 4 cylinder 3.0 (lots of them in marine applications) Iron Duke engine with a 5 speed and decent rear end gearing, say around 3 to 1 with a .75-80 OD 5th.
I put a 73 Nissan Z car engine in a 720 Pickup frame, with a 49 Plymouth businessmans coupe body, sectioned and channeled, with a 4 speed and it weighed 2350 when I fininshed, about 3200 stock.
regards
Mech
Old 06-28-2012, 09:58 PM   #19 (permalink)
build me one .
Excess gears = higher drivetrain losses.
Old 06-28-2012, 10:23 PM   #20 (permalink)
I like the 3.5v6 I have in the Impala, but only way it would work would do FWD conversion. I'm a KISS guy, find a crashed Camero (just realized my son's name is Camero plus a N on the end) or Firebird V6 5 spd and swap that in, or S-10 4 cy and 5 spd would be easy if that's enough power.
