Here is the Schematic for the driver board Rev 1.3.
One thing I noticed on the ones of these that are purple is this board house has thicker plating then older versions. This means the diodes do not fit in the holes nicely. It takes either drilling (not recommended) the holes where the diodes go, or my preferred method of just hitting the leads a bit with some emery paper to thin them down.
Assembly Guide should be done this week.
-Adam
