Old 03-13-2012, 01:19 PM   #1 (permalink)
PSmodder lurker
Nissan takes a brave leap in Le Mans
A revolutionary shape and approach, Nissan will support the 'Batman' DeltaWing, to be tested @ Le Mans- June 16 - 17!!
The radical aero/chassis configuration and turbocharged 4-cylinder will showcase pioneering technologies. Extreme solutions on aerodynamics & weight reduction created an unusual racing package. The Nissan team has well-seasoned partners - designer Ben Bowlby, motorsport icon/businessman Don Panoz, F1 legend Dan Gurney, championship team Highcroft Racing and Michelin Tires. Confirming drivers, Marino Franchitti & Micharl Krumm. Rulebook be damned AND burned! This should be a very interesting & historic attempt.
The Following 4 Users Say Thank You to botsapper For This Useful Post:
aerohead (03-14-2012), robertwb70 (03-25-2012), Rokeby (03-17-2012), Sven7 (03-14-2012)
Old 03-13-2012, 02:12 PM   #2 (permalink)
Not too long ago, 1-2 years a very similar design was being promoted for F-1. I think it had the same name, Delta-Wing.
I like the idea of a low frontal area, but isn't this going to handle like a 3-Wheeler?
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
Old 03-13-2012, 02:41 PM   #3 (permalink)
PSmodder lurker
The 'Made in the USA' DeltaWing team has been in development since 2009 for the IndyCar Series. Chip Ganassi supported the initial development but chose a Dallara design instead. It has been picked up by Nissan for the 2012 24 Heures du Mans. The delta wing shape is so unique & so narrow it is looks like it would not work in the wildly changing dynamics of road racing. The engineering/design criteria targets are utmost aerodynamic efficiencies & lightest structural weight (Colin Chapman is fluttering his wings). Ben Bowlby wins Aerodynamicist of the Year award. Michelin designed & developed specialized performance tires. Only 4" wide x 15" front wheels! ALMS champion Highcroft Racing will manage the endurance race preparations.
But still, how will it turn?!!!
Old 03-14-2012, 08:37 AM   #4 (permalink)
It's a shame the design wasn't chosen for IndyCar... but such a revolutionary design would have to prove itself before being let loose on the track.
From what I can tell from the literature (just finished writing a feature on this for another website), the center of gravity is far back between the rear tires. This means there's almost no load on the front tires.
While this ought to mean that turning will be difficult, 911s seem to turn all right with the engine and most of the weight slung out behind the back axle. Furthermore, the DeltaWing will be
The layout is incredible. The front tires are tiny, the front brakes are tiny, the front suspension looks like what you'd see on a bicycle. Dry weight is under 500 kgs, around 200 kgs less than what an unrestricted gasoline LMP2 would weigh and some 300-400 kgs less than the diesel LMP1s.
The big question is whether the low weight and low overall drag will balance out the lack of power down those looooong straights at LeMans.
Old 03-14-2012, 09:45 AM   #5 (permalink)
On a 911, braking torque cause by the front wheels shifts the center of inertia to a 50/50 weight balance during hard braking (entering a turn).
They also have the weight in the back for traction for powering out of a turn.
I'll post the simple diagram illustrating this, which I recall - once I find it.
Here is a thread on the topic:
Weight transfer vs brake bias - Page 2 - Pelican Parts Technical BBS
Chin Spoiler:
Roof Wing
Old 03-14-2012, 11:33 AM   #6 (permalink)
2003 Ninja EX250 - '03 Kawasaki Ninja EX250
90 day: 78.57 mpg (US)
Saturn - '99 Saturn SL1 Base
90 day: 47.27 mpg (US)
I wouldn't drive that at high speeds.
It's backwards, in terms of aerodynamic efficiency and stability.
Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it!
If you have to use your brakes, you are driving too fast!
My 101.5 MPG 2003 Kawasaki Ninja 250
Crude Oil Price Today
Old 03-14-2012, 02:54 PM   #7 (permalink)
Cool! We'll see how it works. I like this class of Le Mans cars, and I hope they are the beginning of a new trend. They did this back in the 1960's with the Panhard LM64 -- that car only had a 1L 2 cylinder motor and could go ~155MPH. This car with a 1.6L should go at least that fast.
Last edited by NeilBlanchard; 03-15-2012 at 03:07 PM.. Reason: corrected Panhard LM64
Old 03-14-2012, 03:38 PM   #8 (permalink)
Some better pictures of the Nissan DeltaWing:
If nothing else, it could be the next Batmobile! :-)
Old 03-14-2012, 04:27 PM   #9 (permalink)
1960's with the Panhard 64LM
Is that the blue car which you post once in a while?
I cannot seem to find information on it.
Chin Spoiler:
Roof Wing
Old 03-14-2012, 04:35 PM   #10 (permalink)
Edited version............for debate
Automobile 2 - Odds and Ends pictures by kach22i - Photobucket
I would have assumed that a shorter, or more conventional wheelbase would be more stable, but still unstable.
The extra length makes it look like a dragster.
The reason for a dragster's length is the torque and counter moment arm of the length to balance it, right?
Do these two designs (Delta Wing and Dragster) have anything in common?
Chin Spoiler:
Roof Wing
