Old 04-11-2008, 01:37 AM   #21 (permalink)
From the Autospeed Brake Specific Fuel Consumption link:
Maybe this is why 1000-1200 ft/sec is better than lower speeds?
My old Thermodynamics professor use to say heat transfer is a slow process. I dont think its why.
Old 04-11-2008, 08:04 AM   #22 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
At least 60% of the energy in an ICE is lost as heat. Thermal losses through the cylinder walls are significant at any rpm but more so at lower rpm.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 04-11-2008, 10:54 AM   #23 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
A few notes on Large diesels operating more efficiently at lower speeds
1) CRAZY long strokes = Higher Mean piston speeds
2) Diesel must have a different burn rate than Gasoline
3) Diesel components are forced to be stronger due to stress, heavier= stronger = more reciprocating mass= less reciprocations to reduce energy loss in reciprocations
I'm no expert here, but it is what came to mind.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 04-11-2008, 11:04 AM   #24 (permalink)
Green Rodder
Grease Beast - '92 Dodge D250 Standard
Econo-Beater DX - '92 Toyota Corolla DX
IIRC when it comes to diesels it's based mostly on torque. They best way to figure that is to get it dyno tested. Since the torque curve will always change when you mod the motor this will have to done every time you make a mod. With this knowledge you will know exactly when to shift the tranny.
Old 04-11-2008, 11:42 AM   #25 (permalink)
True about the heat losses, I dont have the source handy but the majority of the heat lost in a ICE is pumped out of the engine through the exhaust and replaced with cool intake air. The actual losses to the engine coolant is small in comparison. Thats why air cooled engines can exist.
Old 07-12-2008, 09:55 AM   #26 (permalink)
No, it's roughly 1/3 lost to engine heat and 1/3 out the exhaust.
Agreed - heat loss is the problem with low piston speeds. In general, you want high piston speeds, quick burn rate, high cylinder temps and pressures, long stroke, high compression, and insulating materials or coatings inside the combustion chamber (aluminum is not your friend).
Of course you also want the engine to stay in one piece.
Old 07-12-2008, 03:26 PM   #27 (permalink)
piston speed
I don't recall where, but someone once provided a link to an engineering text that mentioned 1000-1200 ft/mn as optimal piston speed for economy.
My question is, is that true and why is it?
Why wouldn't, say, 700-840 ft/mn be even better?
Boy Frank,that's a new one for me.Although many things are new to me.I was looking at BSFC maps last night and don't recall a term like that even on the charts.Rpm seems to matter.Road load is an issue.Volumetric efficiency.The oil ring,by itself,is supposed to be responsible for 10% of all engine friction.And friction is given as a square function of rpm and is borne out by the curves for internal friction.I'll look into it,but off the top of my head,I'm clueless.It's worth knowing,and it seems like there would be a context to if making such a general claim like that.Maybe there's a powerplant expert in the house?
Old 07-12-2008, 04:30 PM   #28 (permalink)
You won't see piston speed on a map because the only way to change it independent of RPM is to redesign the engine.
You can build an efficient engine for 100 rpm or for 3000 rpm - and the 100 rpm one might have more friction losses.
Old 07-14-2008, 02:14 PM   #29 (permalink)
Sorry everybody,I took a couple days to dig through my rat's nest.Here's some stuff I culled out.The only statement citing an optimum piston speed range is from "Internal Combustion Engines",an old textbook,by Edward F. Obert.Piston speed wasn't even listed in the index,but after forraging,I found this citing:-------------------------- "...large and small diesel engines(designed to develop 125-200 bmep),attain their minimum specific fuel consumption in the range of 1,200-1,500 ft/min mean piston speeds."------------------------------------- A large-bore 100-rpm,700 hp/cylinder diesel engine for direct propeller drive was given with the lowest BSFC,@ 0.32 lb/hp-hr.------------------------------------ Friction seems to be the overriding factor for maximum BSFC.----------------------------------------- for spark-ignited gasoline engines,best BSFC occurs at point of maximum charge loading efficiency,which is basically where torque peaks,which is at about 80% load.At light load,or full load,efficiency suffers.--------------------------------------- BSFC maps showed minimums of about 0.45 lbs ( 275 grams ) per hp-hr.(0.746 kWh).-------------------------------- The Orbital Engine Co. 2-stroke is rated at 7-12% better BSFC,but they can't seem to clean up the emissions enough to use it.------------------------------------------- SAE said that an"adiabatic compound engine" operating at 1,300-1,500 degrees F,with no cooling system,and all waste energy into exhaust,could be harvested with compound turbos doing double duty,supercharging and doing shaft work with a BSFC 0.29 lb/hp-hr.------------------------------------ I guess that means a ceramic engine we've been hearing about for 20-years or so.
Old 07-14-2008, 02:43 PM   #30 (permalink)
bryn's Avatar
sputnik - '93 oldsmobile silhouette
90 day: 23.23 mpg (US)
home sweet home - '92 ford clubwagon E-350 xlt
very excelant - '92 honda civic vx
so if 80% load at ~1700 rpm is 50 hp, that is only the most effecient engine speed if you need 50 hp. most of our cars might only need 15 hp to cruise down the road at 55mph.
if we change the gearing so that 15 hp is closer to 80% load, maybe down around 1000 rpm. the engine will still be more effecient even though piston speed is less than ideal.
a manual cvt and a scan guage setup would be really interesting to see
News: Utah Considers Joining 80 MPH Speed Limit Club MetroMPG General Efficiency Discussion 68 11-04-2009 07:25 PM
News: Switzerland cutting speed limits to reduce emissions MetroMPG General Efficiency Discussion 7 09-18-2008 12:02 PM
Field Weakening Experiment for Speed Increase TomEV Fossil Fuel Free 12 04-10-2008 03:53 PM
Series Motor - Speed vs Torque TomEV Fossil Fuel Free 3 03-02-2008 12:27 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
