Old 12-23-2023, 03:18 AM   #31 (permalink)
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
In one of the recent Cybertruck reviews, the designer commented the closed covers reduced aerodynamic drag.
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
The Following User Says Thank You to bwilson4web For This Useful Post:
aerohead (12-23-2023)
Old 12-31-2023, 05:28 PM   #32 (permalink)
BlackGold6.4's Avatar
Location: North of the 55 parallel Mb Canada 740kms(500miles)north of Winnipeg
I'm not sure but would these pizza covers affect brake cooling and if it does I would image only in stressful situations.
Some day in the future I will get 12L/100Kms out of my Ram 2500
Old 12-31-2023, 08:23 PM   #33 (permalink)
Engineering first
Most of the Tesla braking is regenerative, not friction. There is a 'rubbing' probably there to minimize rust on the disc but not enough to make them hot.
You've reminded me to check for anti-drag springs.
Bob Wilson
BlackGold6.4 (01-01-2024)
Old 01-03-2024, 10:26 AM   #34 (permalink)
' stressful situations '
https://ecomodder.com/forum/member-a...-ultralite.jpg
If it were the mid-sixties, and you were exiting Le Mans' Mulsanne straight, and braking into the curve at 218-mph in a Ford GT-40, it would be a # 10 pucker. But in 'normal' daily driving, all your brake components would be 'over-engineered.'
As long as you drive 'ahead' of your surroundings, and remain completely vigilant, watching for 'everybody' around you, it's less likely that you'd be 'surprised' enough to get into some 'panic stop' situation. Even then, the mass of the rotors and drums would absorb enough heat without allowing brake fade.
GM's 1992 Ultralite wheel covers would be an example of 'good compromise.'
Name:	member-aerohead-albums-other+vehicles+1-picture125-cd-0-19-nets-100-mpg-gms-ultralite.jpg
BlackGold6.4 (01-03-2024)
Old 01-05-2024, 10:13 AM   #35 (permalink)
I wondering if this is even feasible on a rim and tire where there's more rubber then rim. So my example is 35" tall tire with a 17" rim, that's 18" of rubber with side biters sticking out. These are E rated tires and very heavy so I'm thinking everything is against me. I think that an air dam in front of the tires for highway use is going to be more beneficial. Give me your thoughts.
Old 01-05-2024, 10:39 AM   #36 (permalink)
Engineering first
. . . I think that an air dam in front of the tires for highway use is going to be more beneficial. Give me your thoughts.
This sounds like an excellent experiment using cardboard and duct tape. Benchmark 10 miles each way using A-B-A at say 65 mph between 10 PM and 5 AM.
Then take 5 mph steps up to find out the maximum speed before the tape+cardboard pieces blow away. This will give insight for what a permanent fixture might take.
Of course it you reach 80 without them stripping out, use the the worst off road trail and test how well the tape+cardboard parts remain.
Take lots of photos.
Bob Wilson
The Following 2 Users Say Thank You to bwilson4web For This Useful Post:
BlackGold6.4 (01-05-2024), Joggernot (01-06-2024)
Old 01-05-2024, 12:57 PM   #37 (permalink)
Bob Wilson
Can't wait try this experiment but it will have to wait till summer. It's -30c right now so tape doesn't stand a chance.
Old 01-06-2024, 10:54 AM   #38 (permalink)
' feasible '
Ford built an 'Atlas' 1-ton concept truck with battery-powered, electric, wheel-shutters, all-around, which remained 'closed' until needed, and they worked in conjunction with a wrap-around airdam upstream.
Historically, 'any' wheel 'porosity', of any degree, has been 'fair game' for streamlining, beginning in WW-I.
Alaskan bush planes, with enormous flotation tires still employ 'MOON' covers on their' relatively-tiny' wheels.
BlackGold6.4 (01-30-2024)
